Introduction: Raspberry Pi + WebCam + IR Remote Home Controller
Harware :
1. HomeWebCam
2. IR Remote Control
3. Raspberry Pi
How to Make ?
See Above Photos
How it works ?
- Use your Home WemCam Software to control and View.
- When the Laser Pointer point to Device, Remote to ON and Off by WebIOPi
More Information : iMediaBank - http://www.imediabank.com
Step 1:
IR Remote
Hardware
Parts
- Infrared LED: Home TV remote
- IR Receiver: A3H3 and A3I3
- NPN Transistor: B29X 9014
- 1.5Ω Resistor: 1
- 220Ω Resistor: 1
Terminal Install :
- $ sudo apt-get install lirc
For start after boot (Modify /etc/modules):
- lirc_dev
- lirc_rpi gpio_in_pin=23 gpio_out_pin=22
For test only:
- sudo modprobe lirc_dev
- sudo modprobe lirc_rpi gpio_in_pin=23 gpio_out_pin=22
Modify /etc/lirc/hardware.conf
######################################################## # /etc/lirc/hardware.conf # # Arguments which will be used when launching lircd LIRCD_ARGS="--uinput"
# Don't start lircmd even if there seems to be a good config file # START_LIRCMD=false
# Don't start irexec, even if a good config file seems to exist. # START_IREXEC=false
# Try to load appropriate kernel modules LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers. DRIVER="default" # usually /dev/lirc0 is the correct setting for systems using udev DEVICE="/dev/lirc0" MODULES="lirc_rpi"
# Default configuration files for your hardware if any LIRCD_CONF="" LIRCMD_CONF="" ########################################################
Start and Stop lirc
- sudo /etc/init.d/lirc stop
- sudo /etc/init.d/lirc start
Testing
- mode2 -d /dev/lirc0
- result :
space 16300 pulse 95 space 28794 pulse 80 space 19395 pulse 83 space 402351 pulse 135 space 7085 pulse 85 space 2903
Create a new remote map
Check Key List name $ irrecord --list-namespace
# Stop lircd so /dev/lirc0 is not in use sudo /etc/init.d/lirc stop
# Create a new remote control configuration file (using /dev/lirc0) and save the output to ~/lircd.conf irrecord -d /dev/lirc0 ~/lircd.conf
# Edit ~/lircd.conf and add edit the name of the controlled device nano ~/lircd.conf
# Make a backup of the original lircd.conf file sudo mv /etc/lirc/lircd.conf /etc/lirc/lircd_original.conf
# Copy over your new configuration file sudo cp ~/lircd.conf /etc/lirc/lircd.conf
# Start up lirc again sudo /etc/init.d/lirc start TEST # List all of the commands that LIRC knows for 'samsung_tv' irsend LIST samsung_tv ""
# Send the KEY_POWER command once irsend SEND_ONCE samsung_tv KEY_POWER
# Send the KEY_VOLUMEDOWN command once irsend SEND_ONCE samsung_tv KEY_VOLUMEDOWN
# Send the KEY_VOLUMEDOWN command 10 times lowering the volume for 10 units at once irsend --count=10 samsung_tv KEY_VOLUMEDOWN
Step 2: WebIPOi
Main Page : https://code.google.com/p/webiopi/
- WebIOPi is a very useful for developer to control GPIO from web page by python.
Installation
WebIOPi is developed and tested on Raspbian. You only need Python, either 2.7 or 3.2. Download, then extract and install WebIOPi. The setup script will automatically download and install required dependencies using apt-get. You may have to manually install GCC and Python development headers if you are not using Raspbian.
Update note: Stop your existing WebIOPi service, then process with the setup. Your configuration will be kept but others files will be override.
See downloads page to get latest package, and adapt x.y.z with the version you download.
$ tar xvzf WebIOPi-x.y.z.tar.gz $ cd $ cd WebIOPi-x.y.z $ sudo $ sudo ./setup.sh
Setup may take a moment.
Running WebIOPi
Finally, use webiopi command :
$ sudo webiopi [-h] [-c config] [-l log] [-s script] [-d] [port]
Options: -h, --help Display this help -c, --config file Load config from file -l, --log file Log to file -s, --script file Load script from file -d, --debug Enable DEBUG
Arguments: port Port to bind the HTTP Server
For instance, to start with verbose output and the default config file :
$ sudo webiopi -d -c /etc/webiopi/config
You're done, and ready to enjoy WebIOPi ! But the server and GPIO state will be lost when you'll stop the script (CTRL-C) or close the terminal.
Running WebIOPi (Daemon)
You can also start/stop the background service, the configuration will be loaded from /etc/webiopi/config.
$ sudo /etc/init.d/webiopi start $ sudo /etc/init.d/webiopi stop
Auto start at boot
To setup your system to start webiopi at boot :
$ sudo update-rc.d webiopi defaults
To remove webiopi start from boot :
$ sudo update-rc.d webiopi remove
Usage
If your are directly using your Raspberry Pi with keyboard/mouse/display plugged, open a browser to http://localhost:8000/
If your Raspberry Pi is connected to your network, you can open a browser to http://raspberrypi:8000/ with any device of your network. Replace raspberrypi by its IP.
Contents 1 WebIOPi2 Installation3 Running WebIOPi4 Running WebIOPi (Daemon)5 Auto start at boot6 Usage7 Reference
SANKI Device 2-Axis Joystick ADXL3453-axis accelerometer Analogue Sensors Arduino Button Camera DS1307 (Clock) DVK511 EEPROM Heartbeat Sensor Home Remote + Server IR Remote LCD1602/2004 LED ( Simple ) LED / Matrix - 74HC595 LED Light-Emitting Diode Matrix LED 8x8 + Max7219 NE555 Nokia5110 NRF24L01 Photoresistor PIR Sensor PL2303 PWM Dim Control RFID-RC522 RTC-DS1307 Clock + EEPROM AT24C32 Stepper Motor Ultrasonic
Reference https://code.google.com/p/webiopi/
