Introduction: Replacing Engine Vacuum Hoses!
I Got this set of 4 sizes of silicone vacuum hoses off Amazon.com. Here is how I replaced the 17 year old rubber hoses in my car.
Step 1: Replacing the Brake Vacuum Hose.
Using my birdbeak pliers I removed the spring clamps and took off the hose for the master booster cylinder. The second biggest Size vacuum hose is what I used to reinstate the vacuum connection complete with tbolt clamps on either end.
Step 2: Replacing the Fuel Pressure Regulator Hose.
The thin vacuum hose to the fuel pressure regulator was easy to remove and replace with the appropriate size silicone hose. I put tbolt clamps as well here too.
Step 3: Replacing the Radiator Reservoir Bottle Hoses.
Just for good measure I did the same to the radiator Coolant reservoir. Silicone is high temperature tolerant and resistant to corrosion. It is however very easy to cut so in the future I will be careful around any of my new silicone hoses.
