Introduction: Royal Enfield Side Indicator Problem With Angel Eye Fixed
The problem with the LED Headlight For Royal Enfield Bullet 40W 7" ( White & Amber Color Angel Eye) is that the amber ring blinks only with either one of the side indicator right or left ,if left side indicator is connected then it will only work when the left indicator is switched on or vice versa,but now this problem can be solved.both left and right indicator can work individually with the amber angel eye.
Procedure:
take one diode connect the +ve terminal of the diode to the 4" jumper wire and the other end of the wire is connected to the +ve terminal of the left indicator now connect the positive terminal of the diode to the anothe 4" wire and connect the wire to the terminal of the amber angel eye LED at the headlight,repeat the same for the right side indicator and the problem is fixed,now you individualy blink the two indicator because diode is not allowing the flow signal in reverse direction.
you can follow my pictorial guide
Step 1: Components Required :
  1. 2 Diodes IN5408(approx 5 rupee each)
  2. 16 inch jumper
  3. wire black tape
Step 2: Procedure:
Take one diode, connect the +ve terminal of the diode to the 4" jumper wire and the other end of the wire is connected to the +ve terminal of the left indicator now connect the -ve terminal of the diode to the anothe 4" wire and connect the wire to the terminal of the amber angel eye LED at the headlight,repeat the same for the right side indicator and the problem is fixed,now you can individualy blink the two indicator because diode is not allowing the flow signal in reverse direction.
