Introduction: Smoked Duck Szechuan Pepper Stuffed Pumpkin + Rendered Duck Fat
Smoked duck is readily available where I live, so as one of my favourite meats, I chose to stuff my gourd with it. It adds an excellent smoky quality and flavour to the mixture, as well. I removed most of the skin and fat before adding the meat to the mixture in order to render it. Duck fat has a gorgeous flavour that is highly complimentary to many food items. I’ve tried to substitute it with pork fat when cooking shiitake mushrooms, for example, and found myself disappointed with the results. Rendering is incredibly easy. Simply collect the fat, cook in a pot on low heat until the fat is clear and strain into a jar for refrigeration. Once cooled, it should be pure and white. The fat should keep for 2-3 months. Use in place of oil or to add flavour.
The Szechuan pepper is a curious spice. Despite its name, it is not closely related to, nor has much of the hot spicy quality found in the Piperaceae family (such as black pepper). In fact, its genus belongs in the citrus family. It has a sharp, bright flavour, which is known to enliven food. It is also known for its numbing feature. Moments after putting one of these husks in my mouth, I was hit with an odd numbness I’ve never quite experienced before. These peppers are perfect for this dish because of how well they bring out all the flavours.
Step 1: Ingredients and Directions
Ingredients
1 medium or 2 small pumpkins (or your favourite round gourds)
150 grams of chopped oyster mushrooms
100 grams of smoked duck cut into bite size pieces (remove fat if rendering)
1 diced bell pepper (any colour)
½ cup cottage cheese
¼ cup milk (any kind)
45 grams or 1/3 cup of cashew pieces
165 grams or 1 cup of uncooked rice (I used brown jasmine, but basmati would substitute well)
5-6 cloves of chopped garlic
1-3 chopped chilies (depending on your spice tolerance)
1 teaspoon capers
1 teaspoon butter
½ teaspoon salt
¼ teaspoon Szechuan peppers
Directions
Rinse rice two or three times by splashing around in water and draining. Finally, add two cups of water and place over high heat in a pot or rice cooker. Once it starts to boil over, turn heat very low for 20-30 minutes. My little test to check if the rice is done without stirring is to tip the pot slightly. If the rice slides or moves in any way, it needs to cook longer. If the rice doesn’t move, it’s done.
While rice is cooking, fill a large pot with enough water to submerge your pumpkin(s) and bring to a boil. Cut the top off the gourd(s) and remove the seeds and gunk.
Once water is boiling, carefully lower into the water, including the top. Allow it to boil for 15 minutes. It should be soft, but firm enough to hold its shape. Drain water and carefully scoop out the gourd. Place in the refrigerator to cool.
Heat a dash of cooking oil in a frying pan and brown the garlic and chilies. Add the mushrooms and fry until the mushrooms have released their water and have reached a modest golden colour.
Preheat oven to 350ºF/180ºC/ gas mark 4.
In a large bowl, mix all ingredients except pumpkin, butter and milk. Mix.
Pour excess water that might have pooled in the pumpkin and begin stuffing with the mixture. Once filled, pour in the milk to fight possible drying out. Top with butter and replace the pumpkin top.
Bake for 25-30 minutes. While it is baking, clean your messy kitchen and think about how hard you will eat your stuffed pumpkin.
Because you boiled the pumpkin, you can eat all of it, including the skin. Do this very thing.
Enjoy your mouth-gasms.
