Introduction: Speaker Modify!
Hello Guys this is a Speaker Modify that made out of 2 Speakers.This turn two speakers into something like one long speaker with two LED Strip and Two Flashing LEDs with small rigiforms balls shaking upwards with the base of the song.
Step 1: Things You Need
The things you will need are
- CardBoard pieces with measurements given in the Figures
- 2 9v Batteries
- 2 9v Battery Connectors
- Two Speakers
- 2 Flashing LEDs
- 2 Switchs
- Small LED Strip which can use 9v power supply (1 yard)
- A Small Plastic Container
- Red and Black Wire
- Hot Melt Glue Gun
- A Soldering Iron
- Solder
- Black Vanish Paper
Step 2: Pasting With Black
Paste all the Cardboard with black vanish paper and fit the switch as shown in the figure 2
Step 3: Assemble the Speaker!
Keep a cardboard at the bottom and at the middle of the speaker and hot glue it. Now fit the speakers volume controller in the cardboard as shown and make a hole to exit the wires!
Step 4: Front and Side Assemble!
Now assemble the front and the two sides as shown.
Step 5: Flashing LEDs!
Now make a hole and solder the LEDs to the small plastic container as shown.
Step 6: Simple Schematic!
Carefully observe the schematic and fix all together there are some photos of LED Strip and 9v Connector.And the Final Inside Look of the Speaker.
Step 7: And Done!
Set the LED Strip Switch at the Top and now fix the Small plastic container and add Some small rigiform balls to the small plastic container as shown.AND DONE!!!
Enjoy and I wish you a good luck modifying your speakers and DON'T FORGOT TO VOTE ME IN THE SPEAKER CONTEST! :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D]
(((((((::::::::HAVE A NICE DAY::::::::::::))))))))))
Fix It Contest
Plastics Contest
Audio Contest 2017
