Introduction: Start Your First Project With Raspberry : Blinking LED
In this project I am going to show you how to program Raspberry Pi to make an LED blink,If you have nearly bought a Raspberry pi and you don't know anything where to start,this tutorial it fits in.
In addition to your Raspberry Pi running Raspbian, you will need :
1. 330 Ohms resistor
2. LED
3. Breadboard
4. Some wires
Step 1: Install Operating System in Pi
You can skip this step if you have installed the OS already in the Pi.If yes then go to step 2 or else look the complete OS installing instructions in this link that I uploaded.
https://www.instructables.com/id/Build-Your-Own-PC-With-Raspberry/
Step 2: Schematic of the Circuit
Kindly follow the steps bellow :
1. Connect a 220Ω resistor to the anode of the LED,then the resistor to 5 V.
2. Connect the cathode of the LED to GPIO (See the picture above).
Step 3: Watch the Video for More Details
Step 4: Python Code
You are now ready to write some code to switch the LED on.
NOTE : All following steps are explained in the video.
1. Turn on your Pi and Create a new text file “BLINK.py” .
2. Type in the following code:
import RPi.GPIO as GPIO
import time
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(17,GPIO.OUT) #Define pin 17 as an output pin
while True:
GPIO.output(17,True) #Outputs digital HIGH signal (5V) on pin 3
time.sleep(2) #Time delay of 2 second
print( ' Hello ' ) #Print when the LED turn ON
GPIO.output(17,False) #Outputs digital LOW signal (0V) on pin 3
3. Once you have typed all the code checked save it.
4. Run the python code by typing the following code in the terminal:
- cd Desktop and press Enter( I type Desktop because I have saved the file in the pi's Desktop).
- python BLINK.py and pressEnter.
You will see the LED turn on for two seconds and then turn off for two seconds too.
I hope you enjoy with this project.
Raspberry Pi Contest 2017
LED Contest 2017
