Introduction: Thor's Mjolnir
Are you worthy? Welcome to the instruction set to build and complete Thor's Mjolnir. Below you will find a full step process on how to complete your DIY Marvel project. Enjoy and be safe at all times.
Caution use of sharp objects and materials.
1 6x6 piece of wood
Table saw
Wood glue
Drill press
Hammer Handle
¾ inch drill bit
Drill press: drill bit big enough for handle
Sander
Paint and wood finish(Optional)
Step 1: Cutting 6x6
Cut 6x6 inch piece of wood into one 8’ section (Caution sharp objects).
Step 2: Cutting Angles
Cut angles into edges of wood Block ¼ ‘ deep on a 45-degree angle.
Step 3: Cutting Caps
Cut caps for block 1’ thick from the 8’ section.
Step 4: Cutting Corners
Cut corners of Block caps ¼ ‘ deep on a 45-degree angle (Table Saw).
Step 5: Cutting Block Cap
Cut block cap front edges ¼’ on a 45-degree angle (Table Saw).
Step 6: Sanding
Sand all edges to make the smooth
Step 7: Drilling
Drill hole through center of block, on bottom of head (Drill Press).
Step 8: Glue Handle & Block Caps
Glue Handle into the handle hole on the block using wood glue. Then glue the Block caps onto the attached hammer head.
Step 9: Completed Mjolnir
Let's hope you are worthy...
First Time Author Contest
