Introduction: VMix Surface Control 8 Channel & Tally Lights
About: vMix Stuff
Build your own vMix Controller 8 Input camera / videos, based on Arduino Pro Micro/Leonardo.
And Tally Lights 8 Camera using Arduino NANO / UNO.
Features:
8 input Preview Buttons
8 Active Buttons
1 Effect Transition Buttons
8 Input Volume Pot/Fader
8 Preview Tally Lights
8 Active Tally Lights
1 Master Volume
T-Bar Fader
Step 1: Prepare the Stuff
The controller : Arduino Leonardo / Pro micro (Native USB)
Tally : Arduino NANO / UNO
5 Project Boards
1 Multiplexer 16 Channel 4067
17 Tact Buttons
10 Pots/Faders
16 Resistors
8 Green LEDs
8 Red LEDs
Jumper wires (Lots of)
Step 2: Wiring the Controller
Check the Schema and start to wiring the controller
Step 3: Wiring the Tally Lights
Wiring the tally light
Preview pin :
2, 4, 6, 8, 10, 12, 14, 16
Active LED pin:
3, 5, 7, 9, 11, 13, 15, 17
Step 4: Upload the Code
I already compiling & build the code so you dont need the library.
All you do is upload the code using Arduino Builder (check the download link for details)
Step 5: Mapping the Controller
Im using arduino pro micro/leonardo. its Native USB, so I dont need the software MIDI serial Bridge anymore.
The arduino pro micro/leonardo will detect as Standalone MIDI Device.
Mapping the controller using shortcut menu on vMix
Step 6: Tips
The Arduino will start/run the after you uploading it, so its better to
connect all the potentiometers before you turn on the arduino, or you will not be able to mapping the controller.
Step 7: Download
