Make Cutlery for a Leatherman
23,369
64
20
Introduction: Make Cutlery for a Leatherman
In this Instructable I'm going to show how to make cutlery for a leatherman surge.
Step 1: What You Will Need
You will need:
- stainless steel cutlery (I recommend old cutlery because new cutlery is way to expensive)
- sandpaper (dont know what grit but its one fine grit and one rough grit)
- grinding wheel
- work gloves
- safety goggles
- paper
- fineliner
- glue
- Scissors
- handsaw (for metal)
- waterproof marker
for your own safety
were the work gloves and safety goggles
while working with a grinding wheel
Step 2: Copy and Cut
-First copy the shape from the end of the saw or file.
-than cut it out (cut it out as precise as possible because
it will make work easier later on)
Step 3: Mark and Paste
- get your cultery and mark where you want to cut them.
- than glue your copy on behind your line
Step 4: Cut and Grind
- now cut your cutlery to size
- after the cutting you have to grind off the big pieces
- cool your project ones in a while so you don't burn your fingers
Step 5: More Grinding
For this part you have to use the finer side of the grindingwheel.
Try to follow the outline of your copy exactly.
When you are done with grinding the outline you try to fit it in your leatherman.
Keep grinding small bits off until your cutlery fits in nicely.
Step 6: Sanding and More Sanding
In this step its all about the detail, because were going to sand most of the scratches away.
You can use all sorts of grits. Start with a low grit for the deep scratches and then
work your way up to higher grits to get a nice smooth finish.
tip
when using
high grits it's
advised to make
your project wet.
Step 7: Before Use
wash your cutlery before using it so that you won't get all the dirt from the grinding and sanding in your mouth.
Be the First to Share
    • Game Design: Student Design Challenge
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    20 Comments
    jmwells
    jmwells
    9 years ago
    There is no such thing as too many flashlights, too much duct tape, and too many leatherman's.
    berky93
    berky93
    13 years ago on Introduction
    How can you tell if a leatherman has the ability to attach to utensils such as this? I plan to buy one soon and I'd like to be able to make my own, such as these
    aTOMx
    aTOMx
    Reply 12 years ago on Introduction
    Having the Leatherman Wave, I have the Large bit driver that would be good as well to hold the fork and spoon.
    ClayChip
    ClayChip
    I think this is a great idea. Can you close the leatherman with the utensil attached?
    berky93
    berky93
    Reply 13 years ago on Introduction
    I doubt it since the utensil is so big, but it definitely decreases the overall size of everything, you could probably fit a leatherman and a few utensils in one carrying case (that wont end up being as long as a standard fork)
    wilwrk4tls
    wilwrk4tls
    This is definitely a great idea. One of the few I will probably really end up doing myself. Might even be cool enough to justify a second Leatherman that accepts the jigsaw blades... or just act as a knife to complement the fork.
    thepelton
    thepelton
    The higher the number, the finer the grit. Smaller numbers are good for initial smoothing of a surface. Higher numbers, used in sequence, lower to higher, can help you make scratches dissappear, so you can get wood which looks almost like cast plastic, or wood simulated glass.
    TURBOSOPPEN
    TURBOSOPPEN
    cool! but there is a major problem with this,the problem comes when got to use a fork AND a knife at the same time, like when you eat meat.
    jolshefsky
    jolshefsky
    How can you live with only one Leatherman tool? :-)
    monkeysee
    monkeysee
    very nice, this caught my eye with your title but unfortunately I've got a smaller juice S2 which doesn't have the ability to attach other utensils. none the less i still think this is a great idea.
