Introduction: Minecraft Secret Door for a New Two Floor House
in 1st is my first fine house. I know it don't looks but it is really thief proof because it is full of traps and I made some secret doors also like a secret door from 1st floor main room to my ground floor library, and it has 2 basements one secret , secret door near staircase
I got the idea of this instructable when I played gone home
Step 1: Make Staircase
your first step while making house will be making a floor(I didn't made it as it was just a tutorial) .and 2 before making walls make a staircase
Step 2: Make a Wall Near the Stairs
second leave one block and and make a wall the height of your stairs
Step 3: Power Source
move to back side of stairs and wall. and place a block at the base of the wall. then place a Redstone torch on the wall above the block you placed(don't place on wall or else it won't work)
Step 4: Making the Pistons Work
place the redstones as I placed and yes don't forget to place the Redstone repeater. and yes if you did anything wrong it won't work
Step 5: Making a Way Out
where the Redstone end in the torch line start placing blocks in L shape now place a sticky piston on it and stick a block on it. then place Redstone and a button. when you hit the button the piston will cut the connection and then you can move out
Step 6: Button to Move Inside
place a button the opposite side of the torch(I used a stone so you don't get confused you can use wooden so no one gets to know about it. now add blocks over the empty wall and make the left side walk also. you should look like in second pic
Step 7: Finishing Touch
make the walls and the roof(I didn't made roof but I did it in my main house)
Step 8: Enjoy Your Creation
my next instructable will be on a secret door from room on first floor to room on ground floor ( or the opposite) if you have any questions feel free to ask me
Secret Doors and Compartments Contest
7 Comments
1 year ago
woah creative
7 years ago
A good way to make it hidden is to hide the button underground . You can also put a pressure plate a bit further , but how do you trigger the pressure plate AND pass the door at the same time ? The answer is to throw 1 dirt (with Q) , so the pressure plate is triggered then pass . You can make it even less obvious if your pressure plate would be a table or some kind of statue . No one will think that a pressure plate as a table would actually be the trigger to a nice house , right ?
8 years ago
Cool house
thanks and have ya
voted
8 years ago
move two blocks right side and place a button then break the wall from the 2 blocks you skipped and add books instead of it.now it is safe and don't forget that if you are using wooden block use wooden button only it will camouflage with it
8 years ago
is not having a button on the wall a bit obvious? I would think anyone would be tempted to push it, and then find your "hidden" room...
