Introduction: Program a Ardweeny Using a Duemilinove ( No More Ftdi Cable Required!)
ok, this is a simple instructable, i don't know why others have yet to do this (cause its super easy) but basically this instructible came to exist because i was too cheep to buy a ftdi cable.
Step 1: Remove Your Duemilionove's Atmega
to do this, simply use a IC puller or carefully slide a small flathead screwdriver underneath the chip and do the same to the other side of the chip and slowly work it free
Step 2: Bend Your Ardweenys Pins
Ok, so the ardweeny dosent exactly fit into a 28 pin dip socket perfectly so bend the pins by pressing one side of the ardweeny against a table to bend the pins just a little so the will fit the dip socket
Step 3: Plug in Your Ardweeny
finally plug your ardweeny into the duemilionove's dip socket with the ardweenys led facing the usb jack, now your ready to upload and start using your ardweeny on a breadboard.
6 Discussions
8 years ago on Introduction
I am still surprised at thit that apparently you can program an empty chip without bootloader, simply by placing it in an arduino board (after removing the programmed chip).
But, since the duemilanova without the atmega is no more than an IC foot with a crystal and an FTDI chip attached, wouldn't it be possible then to program a blank chip just by connecting it to an FTDI chip (or even a max323 for that matter)
9 years ago on Introduction
What if someone can only afford an Ardweeny
Thanks, I needed this instructibe. One question... Does the clock on the Ardweeny conflict with the clock on the Duemilanove?
Thanks, I was wondering if I could program an ardweeny this way!
10 years ago on Introduction
Gee, wish I'd thought of it before purchasing my ftdi cable! Now I know what to do when I break my ftdi cable in two, something I'm prone to do!
PLEASE RATE AND COMMENT:]
