Introduction: Make Your IPhone Charger Hold / Display Your Phone
We loved this iPhone hack by Brendan Dawes so much we thought we should share it with Instructables :)
It works great for other phones too, I also did one for an old Nokia and a Sony Ericsson, and why not ?! :)
Step 1: What Do You Need...
your phone
the phone charger
sugru
scissors
cling film
some soapy water
If you are not familiar with sugru, you can find out more on our website - www.sugru.com
the phone charger
sugru
scissors
cling film
some soapy water
Step 2: Open the Sugru Sachet
Cut open the sachet of sugru following the dotted line, this is the best way to remove sugru from the special foil sachet.
Knead the sugru in your fingers for half a minute, this helps the material work better.
Tear the sugru into 3 pieces; for this hack I needed 2 large ones and a small one.
Cover your phone in cling film, this will make sense a little later.
Step 3: Pop the Sugru in Place
Press the sugru onto the charger roughly where you need it.
Step 4: Get the Shape Right
Charging your phone creates heat so it's good to make a little space between the phone and the charger to allow air to circulate.
Pop the third piece of sugru onto the top of the charger making sure it sticks out a bit.
Once the sugru is in place, it's time to get the shape right.
Gently touch the sugru repeatedly to tweak the shape, don't panic, you have plenty of time.
Step 5: Create the Perfect Impression
Press your phone gently into the sugru and it will take a perfect impression, creating a snug fit for your phone.
1: To help with this process, rub a little soapy water onto the cling film you wrapped around your phone - soapy water works as a release agent for sugru preventing stuff from sticking to it :)
2: Gently press the phone into the sugru. Be careful, sugru will still be very soft, so be gentle so as not to deform your brackets too much.
After I completed this I realised that this step is not that necessary, so you could skip it if you liked. Take a look at the Sony Ericsson version in step 8 :)
Step 6: Smooth the Surface and Leave It to Cure
One final tip, to create a great smooth surface on sugru, use the soapy water again, just dip your finger into the soapy water and gently rub the surface of the sugru, you will notice that this will remove all your finger impressions giving your hack a slick smooth surface.
When you are happy with the shape of your new charging bracket, leave it somewhere to cure overnight.
In the morning, you will have a great new charging cradle :)
Step 7: Same Hack for a Nokia Phone
Here is the same hack but for my old backup Nokia phone.
I tried this one a little differently and really liked it :)
In this version I created a sock by pressing the sugru around the phone and it works a treat.
Step 8: Ooh, and a Sony Ericsson
The Sony Ericsson was a bit more of a challenge as it has a curved front, but not much of a challenge for sugru :)
This time I just made simple goat horns, I just played with the form a bit and it works great.
