Introduction: Umbrella Solar Bar-b-q
this solar cooker makes cooking outdoors quick, fun, and easy plus think of all of the money you will save on propane due to the fact that it is 100% sun power no propane [=
Step 1: What You Will Need
- An umbrella (for best cooking results the umbrella needs to be at least 120cm if possible)
- Aluminum foil
- Glue (i used Elmers)
- Handsaw
- Tripod (any flowerpot tripod will work)
- Drill
- Tape measure
- Pen or pencil
- Scissors
- Brush
- Aluminum foil
- Handsaw
- Drill
- Tape measure
- Pen or pencil
- Scissors
- Brush
Step 2: Begining the Construction
first open the umbrella fully then glue one strip of tin foil to each side
Step 3: Continuing the Construction
now cut enough foil to finnish covering the inside of the umbrella and glue them in ( this is what it should look like right now minus the tripod and the pan)
Step 4: Cutting
use the handsaw to cut the handle of but leave enough of it to wear the umbrela will still fold all of the way
Step 5: More Cutting
then use a pen to mark the holes for your tripod make sure they are big enough so that the tripod can be removed easily the use the scissors to cut them
Step 6: The Final Step
now find a pan or pot that fits on the tripod and your ready to cook whenever and wherever you like
