10 Minute Light Diffuser
141,121
100
9
Introduction: 10 Minute Light Diffuser
About: Former Instructables employee CHECK OUT MY WORK www.carleyjacobson.com
Make your own light diffuser to enhance the quality of your photos!
This simple design costs less than $5 and can be put together in 10 minutes!
Step 1: Materials
Materials include:
Piece of foam core or cardboard - 30" x 20"
Piece of white tissue paper - 24" x 20" use colored tissue paper to change the light color
Exact-O Knife
Ruler
Gorilla Glue - or other adhesive
Step 2: Draw Lines
Draw lines on the foam core indicated by the dotted lines in the image.
Draw a vertical line at 1" on the foam core.  Draw a vertical line at 24" on the foam core.  Now draw another vertical line at 23".
Draw a horizontal line 1" from the top of the foam core and 1" from the bottom of the foam core.
At the end, round the corners as seen in the image.
Step 3: Cut With Knife
Cut along the solid blue lines with the exact-o knife.
Step 4: Glue Tissue Paper
Align the corners of the tissue paper with the corners of the foam core and glue them together.  See second picture for final product.
The extra foam core on the end will serve as a handle.
Step 5: Use With Photo Station
Use light diffuser to lessen the harshness of the light, block shadows, and more!
Be the First to Share
    • For the Home Contest
    • Big and Small Contest
    • Game Design: Student Design Challenge
    9 Comments
    aerodoc
    aerodoc
    8 months ago
    Consider parchment paper instead of tissue paper. It is heat resistant (you can put it in a hot oven without worry) and has the same diffusive qualities as tissue paper.
    ismalenny
    ismalenny
    8 years ago on Introduction
    can i use white crepe paper instead of tissue paper? how much paper should i use to diffuse light
    gkolve
    gkolve
    11 years ago on Introduction
    Having done quite a bit of light design for theatre I would be a bit concerned that the tissue could be flammable, of course depending on the bulbs you're using and how close you want the diffuser to be to the light source. Parchment paper might be a good alternative as it is used for baking so would hold to higher temperatures.
    ynze
    ynze
    12 years ago on Introduction
    Cool! And the diffuser looks like my brand new iMac too! :-D
    If you buy an extra piece of foam core board, it can be used as a reflection screen.
    edbaby
    edbaby
    12 years ago on Step 5
    Do you have to hold it there, or did you make a frame out of wire to do that? Looks great. Now I gotta make one or some. GR I!
    blackghost
    blackghost
    great instructable , i was thinking about making some studio lights for my brother and will need to make diffusers. i was wondering though , would it be a good idea to make them out of parchment paper, the stuff u can put in the oven.
    That way the lights wont be able to spontaneously catch it on fire........
    or would the paper even get the hot ?
    makerdan
    makerdan
    12 years ago on Step 4
    Are you adding glue only on the corners of the paper? Or all around the sides? Great instructable, btw! :)
    Puzzledd
    Puzzledd
    This looks good- I've been needing something like this- thanks!
