Introduction: 2-Ingredient Candy
This is an easy hard candy recipe that you can make with two things you probably already have lying around the house. You are probably wondering what the trick is?
While I could just tell you, let me give you a moment to guess.
Have you figured it out yet?
Yes? No? Maybe?
Okay. Fine. I will tell you.
The trick here is sugar and lemons. That's it. This is a very easy and simple candy recipe. It is basically old fashioned lemon drops. Aside from being incredibly delicious, the other nice thing about this recipe is that unlike other hard candy recipes, it does not use ungodly amounts of corn syrup.
Step 1: Candy Ingredients
To make this candy all you need is a cup of sugar and two (or more) lemons.
(Note that some of the links on this page are affiliate links. This does not change the cost of the item for you. I reinvest whatever proceeds I receive into making new projects. If you would like any suggestions for alternative suppliers, please let me know.)
Step 2: Juice the Lemons
Juice the lemons into a measuring cup or bowl. It is best to use a strainer to keep out any pulp.
Step 3: Mix the Lemon Juice and Sugar
Combine the sugar with just enough lemon juice to dissolve it. This shouldn't require more than a few tablespoons of lemon juice.
Step 4: Boil
On a medium-high flame boil the mixture until it thickens.
Periodically spoon a little into a cool bowl of water. If it starts to get brittle when dropped in the water, it is ready. Quickly remove it from the flame.
If the mixture starts to turn a dark orange, it is also likely ready and starting to burn. Immediately remove it from the flame.
Step 5: Pour
Pour the candy into a silicon mold or onto a sheet of parchment paper in small drops.
Let it cool to harden.
Step 6: Enjoy
Remove the candy from the mold and enjoy.
Did you find this useful, fun, or entertaining?
Follow @madeineuphoria to see my latest projects.
4 People Made This Project!
- Lil wolfy made it!
- GazD2 made it!
- ROBONERD123456 made it!
56 Comments
Question 1 year ago
Can you add water to the mixture?
Question 2 years ago on Introduction
how is the texture supposed to be before you boil it?\
THICK OR THIN
Answer 1 year ago
You should be checking based on the water test I mentioned and not a specific thickness. You want it to be thick, but not so thick it burns and turns bitter. This is a fine line. After you make it a few times you will just get a sense of where that line is.
1 year ago
I have tried the candy but the result is that it is first became very hard and then became very soft is it supposed to be like that ?
Reply 1 year ago
The candy is supposed to be hard. It might turn a little sticky, but I am not sure why is turning gummy. Just guessing, but maybe you didn't get it to a high enough temperature before letting it set?
Could I add 1/4 cup of salt without compromising the end result? I would love the saltiness with the tangy sweet flavor!
2 years ago
Ooh mine is cooling now!! I hope it turns out, really quick and easy recipe ive used oranges as I had 12 lbs of them gifted to me, ive made jam, marmalade and candied peel so far so was looking for something to use the last of them. Thanks for sharing!
Reply 2 years ago
I hope they turned out well! :)
4 years ago
Can you make it with limes instead of lemons?
Reply 4 years ago
Yeah, I tried it and it worked
Just don’t use too much
4 years ago on Step 6
I used some rasberrys and a Summer fruits cordial to reduce with the sugar turned out really nice and some of the raspberry seeds ended up in the final result but it just made them look that bit better
6 years ago
You could zest the lemons before juicing them. Add the zest to the boil and get lemon candy with candied lemon peel inside.
Reply 5 years ago
That would be ridiculously YUMMY!
5 years ago
I would like to go to my mum's and make some.
6 years ago
Wow. Never thought lemon juice would be one of the two ingredients. Definitely knew sugar would be though. :)
Reply 5 years ago
you can also use water but lemon tastes better
6 years ago
nice recipe, hm i wonder if adding zest is a good idea, you think it will be burn while the mixture boils?
Reply 5 years ago
You could add the zest after the boiling part and before pouring into the mold.
6 years ago
Can i use honey? If so, any tips on how? Thx
Reply 6 years ago
Don't know. You could try. Wouldn't be very hard :-)
