Introduction: 6W+6W Loud Portable Bluetooth Speaker
Step 1: Case
In this project i used a small wood case that i bought some time ago, using a pencil mark the holes for the speakers, find the middle and drill the holes to fit the speaker, sand it to give a smother look, with a rubber you can easily remove the pencil marks
Step 2: Connectors
For the connector i used some small male conenctor, i removed the plastic part and keep only the exposed metal conector, protect it with shrink tube, put black and red togheter and once again use shrink tube to keep it togheter, it fits perfectly.
Step 3: The Speakers
I´m using 10 w speakers, secure the speakers using bolts and nuts, them glue the front part to the main case using wood glue.
Step 4: Bluetooth Module
I had to reuse my first front panel that had the holes to large for the speakers, i used to give a few extra milimiters to the back part of to case, after install the module cut two holes where the led are, using the inside of an empty pen you can "reflect" the bright LEDs to the outside of the case, i filled the inside of the plastic with transparent glue.
Step 5: Connect Everything
Conect the usb power to the module, i solder the two wires,hot glue all the holes and lose wires, i had a little plastic piece to the switch to be abble to control the module from the outside of the case.
It has two modes:
Usb: when cable is connected charges the battery and you can use it while is charging
Battery: uses battery
Step 6: Time to Play
It works perfectly, when conected to the bluetooth source it gives a small beep and its ready to play,
the sound is clear and i was impressed because it is incredible loud i was not expecting such a powerfull sound from this small module !
Tank you for watching
