Introduction: Carving a Spine Hiking Pole
This spine shaped hiking pole is carved in a rough shape of a spine. It helps protect and support your real spine when hiking/walking. I carved it from willow using simple wood carving tools, which isn't the best wood to use but it turned out pretty strong, it only flexes a little under my whole weight, I'd recommend using a harder wood for this, but willow happened to be the best stick I could find locally.
I used some simple wood carving gouges and a Dremel to carve this stick, it took about two days to carve. The gouges I used are a 3mm veiner, #6 1/2" fish tail and a homemade gouge which is about a 1" #5.
Step 1: Selecting Your Pole and Preparation
The first thing to do is select a branch with a slight bend in it in the approximate shape of a spine. Ideally you want a nice hardwood but almost any branch will work, you can use freshly cut branch or old deadwood. Make sure that it doesn't have too many small branches or knots. If you use fresh (green) wood you do run the risk that it might split/crack, especially if it is dried too quickly
Once you have your branch selected, you can strip the bark off. With some types of wood you will be able to peel the bark off easily other may need a little more force with a knife.
Step 2: Carve the Handle Shape
The first thing I did after preparing the branch was to carve the rough handle shape. It can be whatever shape you find comfortable. I chose to carve a simple "oval" shaped handle. I simply made two stop cuts at either end of where the handle is to be and then used my knife to put a gentle curve towards these.
Step 3: The Curved Part of the Vertebrae
For the curved parts of each vertebra I firstly marked sections at roughly 1.25" increments. Where I had made these marks I cut a "V" shaped groove around to begin the shape of the vertebra. To make the curves between these I simply used a gouge to cur around the stick. The gouge I used is around #5 sweep, I don't know the exact size because it's a home made gouge. These curves should be around 2/3'rds of the way around the stick, leaving space for the bones that stick out of the spine.
It'll probably take a few brews before you carve them all!
Step 4: Rough Out the Protruding Bones
Next I roughed out the shape of the bones that stick out from the main part of the spine. Because it's a walking/hiking stick, these are just a rough representation of the actual bones. I used a 3mm veiner to rough out the shape. I also made a stop cut at the base of the middle bone using an #6 fishtail gouge, this is for later when I shaped the middle bone..
Step 5: Shape the Two Outer Protruding Bones
Next I used my #6 fishtail again to shape the outer protruding bones. Firstly I made a stop cut around the outside of the bone and then cut into this from the inward curved main part of the spine. Then I used the corner of the fishtail to shape the curve of these bones.
After I had carved all of those, I used my homemade gouge to continue the inward curves on the vertebra smoothly into these protruding bone parts.
Step 6: Carve the Centre Protruding Bone
The centre bone is simply shaped using my #6 fishtail upside down, push it along all the way to the stop cut that you made earlier. The bone is tapered towards the stop cut so you'll want to start lifting the gouge towards the end of the cut. This should lave a smooth curved bone, but you might need to touch up the sides around this cut with a veiner.
Step 7: Finishing
Now you can make the finishing cuts and reshape any misshapen parts. Make sure you tools are razor sharp!
I used a Dremel with a drum sander attachment to sand the curves of each vertebra and a small burr bit to clean up any rough parts around the protruding bones.
For the finishing I used several coats linseed oil just rubbed into the wood with a soft cloth, this gives a natural protection for the wood.
Finalist in the
Humana Health by Design Contest
29 Discussions
5 years ago
I Just started wood carving and love this idea! l'm gonna try it for sure.
9 years ago on Introduction
props on using the mora, a true woodmans knife
Is it strong it looks a little thin at the bottem and its just sexy amazing btw
9 years ago on Step 7
thats just amazing i will bash anyone who says other wise great job!!!!!!!!!!!!!!!!!
9 years ago on Step 3
I'd love to see an Instructable of how you make home made gouges. That one you have there looks mighty nice to me!
10 years ago on Introduction
If only I had woodworking skills ='(
Trial and Error, as they say!
Great ibby, btw, I plan on integrating a custom steel blade.
Again, great job!
If you're patience you can just wrap a branch with some rope and wait. It'll grow similar. I've seen plenty of vine choked woods walking in woods.
Thanks, that should be interesting, post us some photo's when your done!
10 years ago on Step 4
So a spoon gouge does most of the work here?
Reply 10 years ago on Step 4
Fishtail gouge did most of the work, but a straight gouge would work just the same.
10 years ago on Step 7
very very nice, I may need to carve one
You should sell these on www.etsy.com
That's a good idea, thanks.
This is beautiful! Great work.
Thanks canida.
wow, what a fantastic instructable. it certainley looks the part.
Thanks!
Dynamite idea!! and a well done ible as well... I can see what one of my summer projects is going to be, this will go GREAT at the haunted house !
Thanks, please post some photo's if you do carve one!
VERY cool!!
