Introduction: Altoids Scotch Tape Dispenser
There are many things you can make from Altoids tins.
From speakers to survival kits.
I like to keep my lavalier mics in Altoids tins.
Here is one more thing you can make from the tin - Scotch Tape Dispenser.
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1:
I did a few cuts so I could make a blade.
Step 2:
Then I made some teeth and did a bit of sanding.
Step 3:
I glued a cork and cut it to size.
Step 4:
I put some glue on the blade, so it would not bend when the tape is cut.
Step 5:
I added a label.
Our Altoids Scotch Tape Dispenser is ready!
You can use it to cut pieces of tape (obviously) or flip the tape around to seal parcels with ease.
Thank You for taking time to check out this Instructable!
