Introduction: Anti-doorbell
The Arduino project creates a way to prevent a doorbell from activating continually when the doorbell is pressed. The code is really simple to follow.
One installed doorbell system (represented by a four pushbutton or single wire)
One Arduino
One 5V relay module
One 3 pin cable
Step 1: Relay Attachment
Setup Arduino with the relay on the pin defined, for this example it is pin 13, this pin also lights the built in led, good for testing relay signal.
Step 2: Test Circut
Program the Arduino with following code and attach test pushbutton or wire connected to pin 2 to simulate doorbell. When delay times are to your likening prosed.
// copy and paste the following into a new Arduino IDE Sketch
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
void setup() {
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT_PULLUP);
digitalWrite(ledPin, LOW);
void loop() {
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == LOW) {
// turn LED on:
digitalWrite(ledPin, HIGH);
delay(2000);
delay(1000);
delay(2000);
delay(60000); // 60000 = One Minute
Step 3: Cable Prep
If you have crimp connectors prep your cable by cutting one wire or tin the tips with solder, preferably the positive or hot side.
Microcontroller Contest
