Arduino Output Tester Using LED #Xolcano
Intro: Arduino Output Tester Using LED #Xolcano
This is a simple and very useful Project whenever you are working on any prototype you can use this to save time ..! so letz get started
STEP 1: Components Needed
1) LED 3mm -#7
2) 1k Resistor- #7
3) perforated breadboard
4) soldering lead
5) soldering Gun
6) wire stripper
7) double tape(optional)
8) Electrical tape (optional)
2) 1k Resistor- #7
4) soldering lead
5) soldering Gun
6) wire stripper
STEP 2: Led Wiring
place all the led in one column here the important is all the LED's Anode and cathode should come in same side don't connect it in wrong side.
then connect all the cathode and solder , and connect it to the Male header ,so that it can be connected to arduino ground
STEP 3: Schematic Diagram
connect all the components as per the schematic diagram !!
STEP 4: Resistor ,LED Interfacing
connect each resistor in between LED anode to Male header individually so that it make output tester ! then solder all the legs of LED and RESISTOR ,and cutoff extra length ,
STEP 5: Covering
cover the bottom part of the PCB which is soldering part with Double tape and other part with black electrical tape ! which gives long life to it !!
STEP 6: Test It With Arduino
connect the Arduino ground to breadboard ground and Arduino 5v to one of the LED ! and test it with all the LED one by one !!
STEP 7: Yes ! It Works for Both 3.3v and 5v Arduino Supply !!
Test it with Both 5v and 3.3v ,for me it worked well for both the supply !!
I hope you will build it soon,Thank you have a nice Day !!!
2 Comments
bill.harvey.100 8 years ago
A short description of what this is designed to do and possible uses would be helpful along with a schematic.
AXR AMAR 8 years ago
### 5v-1k resistor-LED(pos)-LED(NEG)- GND ###
