Introduction: Automatic AC With Temperature Sensor
Dear Friends,
I have made a Automatic AC with temperature sensor, and this project I have made it if the temperature if is getting warmer the motor will turn on and it gives a indication of led that the place is warm or getting hot. And when the the place is getting cold and it gives a green light an turns off the motor.
- Arduino Uno 3
- Temperature Sensor (TMP36)
- DC motor
- 1k(ohms) Resistor x2
- Green and Red LED
- Breadboard
Step 1: Circuit Diagram
- I have used temperature sensor and connected it to the Arduino at GND, 5v and data pin using breadboard.
- I have also used LED's green and red and connected it to the resistors of 1k(ohms) to control the current of led.
- I have also added motor and connected it to Arduino using breadboard.
Step 2: Programming
First in void setup i have wrote the pin no's of the electronics and i wrote serial no. In void loop i have written the code for temperature sensor and then wrote the motor and led.
Please find the below of my tinker card project............
https://www.tinkercad.com/things/lxa5UQsESbI-automatic-ac-with-temperature-sensor/editel
