Introduction: BETAFPV 1S BT2.0 Battery Charger 4.2V Mod
This simple reversible mod change charge voltage from 4.35V down to 4.2V, thus reducing battery wear
  1. BT2.0 Battery Charger and Voltage Tester V2 (Link)
  2. Soldering iron
  3. Solder
  4. [Optional] Thin wire
Step 1: Split the Case
Split the case by hand or use a knife to pry open
Step 2: Take Out PCB
PCB is just tightly fitted in the plastic case an can be removed by hand
Step 3: Find Voltage Set Resistors
According to documentation voltage set resistor is connected to FB pin. To be sure you can measure resistor value with multimeter without desoldering it. It should be around 40kΩ - 50kΩ
Step 4: Bridge Resistor to Make 0Ω Connection
Max charge voltage can be changed by changing resistor value.
Manufacturer set it to 4.2V + 0.15V = 4.35V which according to the formula requires Rx = 0.15V / 3.01 / 10^(-6) = ~50kΩ resistor.
But to set it to lowest possible voltage 4.2V resistor should be aka no resistor.
This can be achieved 2 ways:
  1. Solder thin wire to both sides of the resistor to short it (recommended because it can be easily undone)
  2. Desolder resistor and bridge the pads with solder
Step 5: Test
Now it should charge to roughly 4.2V
