Introduction: Beebeecraft Tutorial on How to Make Blue Seed Beads Bracelet
How to make a blue seed beads bracelet? Today’s Beebeecraft tutorial will show you the making progress of the bracelet and hope you can admire the tutorial. Seed beads bracelets are some people’s favorite. The white, golden and the blue will make the bracelet both fresh and luxurious, perfect for summer wear. Now, let’s learn how to make the seed beads bracelet.
Step 1: Supplies Needed to Make the Blue Seed Beads Bracelet
2x1.5mm Mixed Color Grade
a Glass Seed Beads Blue
4.5x1mm Flower Tibetan Silver Spacers Beads
6mm White Glass Pearl Beads
12×1.5mm Tibetan Style Toggle Clasps
4~10 0.7~1mm Golden Iron Jump Ring
Tail Wire Nylon-coated Steel
Cutting Pliers
Step 2: How to Make the The Blue Seed Beads Bracelet
Step 1: Make the pattern of the bracelet
1st , cut off three tail wire nylon and slide them in a golden together.
2nd , slide a Tibetan flower sliver spacers beads, a white pearl, and then a Tibetan flower sliver spacers beads orderly .
3rd , separately slide some blue seed beads to the three strings, and then repeat the actions four times.
Step 2: finish the Blue Seeds Beaded Bracelet
1st , separately lock a golden pin to the finished chain pattern.
2st , add the Tibetan style toggle clasp to the one sides of the finished seed beads chain, and then add a golden iron jump ring to the other side.
Step 3: The Results Are Shown in the Figure
Wow! How easy it is. Don’t you want to have a try? Don’t hesitate anymore. Just buy the materials and take action! Fine seed beads bracelet can be created in few minutes and they can help you jewelry making lovers to customize your style and mode. Hope you will like the tutorial.
