Introduction: Beebeecraft Tutorials on How to Make Cute Key Chains
In this project, I will share you how to make cute and easy DIY key chains! It’s really friendly to green hands. Follow my steps and get your handmade key chains now!
Step 1: Materials and Tools Needed:
Mixed size colorful charms
4mm white round pearl beads
8mm white round pearl beads
15x10mm clear drop glass beads
40mm golden ball head pins
5mm golden jump rings
8mm golden jump rings
67x30mm key chain clasp
DIY jewelry pliers set
Step 2: Step 1: Prepare Your Bead Loops
1st, use a head pin to thread a drop glass bead.
2nd, bend the pin with the help of your jewelry pliers.
3rd, cut the pin to make it as long as enough to make a small loop.
4th, make a loop with round nose pliers.
Step 3: Step 2: Make the Bead Strands
1st, use the pin to thread the beads you want to use.
2nd, repeat the same steps to make bead loops.
3rd, find some jump rings and charms that you want to use.
4th, connect them together and make the bead strands.
Step 4: Step 3: Add the Jewelry Findings to Finish the Key Chain
1st, repeat the same step to make make the bead strands.
2nd, add the components with the big clasp. The project is finished.
Step 5: The Keychain Is Finished!
Look! They are very cute dangle key chains! I use different charms to make two styles of key chains. Which one do you like better? Welcome to find more jewelry making supplies on Beebeecraft!
