Big Screw Nutcracker
Intro: Big Screw Nutcracker
This is a nutcracker design that is easy and satisfying to use. It will break open tough nuts with a smooth turning action and offers exquisite control. Inspired by the Over Engineered Nutcracker, this design is a combination of wood and metal construction. It can be held in one hand with the nut in place, while the other hand turns in the screw. It is very convenient and pleasant to use. This Instructable describes the main construction details involved in making this style of nutcracker.
STEP 1: Materials
You will need a big screw and a small chunk of strong wood. Clear maple was rescued from the firewood supply in the author's case. The nutcrackers shown here have big stainless steel 3/8-16 Allen head cap screws 3" long. The pressure pad for the end of the screw was made on a lathe from 3/4" diameter stainless steel bar stock, and 3/4" diameter brass rod for the threaded bushing.
STEP 2: Forming the Body
The rectangular body of the nutcracker measures about 3-1/2" by 3" by 1-1/2". The nut pocket was hollowed out with a 2-1/8" diameter Forstner bit to a depth of 1-1/4"; this left a 1/4" thick wall behind the cavity adding needed strength to the cracker. The round shaped cracker started from a slightly wider chunk of wood to leave a slightly thicker wall around the nut pocket; after boring out the cavity, the blank was cut and sanded to the round outline. This shape fits the palm of the hand very nicely. The hole for the brass bushing is centered so that axis of the screw is in the center (i.e. front-to-back and side-to-side) of the nut pocket. The threaded bushings are shown in the photo.
STEP 3: Machining the Big Screw
The end of the screw was turned down to the minor thread diameter for a short length as can be seen in the photograph. These particular screws have very finely finished smooth and almost polished threads, which makes for smooth operation of the nutcracker. The pressure pad is turned from 303 stainless steel. The concave conical end helps capture and keep the nut in place as the screw is turned. The other end is shouldered and bored to fit the screw end; upon final assembly it is secured to the screw with retaining compound.
STEP 4: Handle
The handle for cranking the screw is a 2" length of 1" diameter birch dowel bored to accept the head of the screw. The ends are rounded and sanded smooth for a comfortable grip. The handle is secured to the screw with a generous application of clear epoxy.
STEP 5: Beeswax Finish
A good finish for items used with food is a mixture of beeswax and pure mineral oil. In use, this compound is slightly warmed until very soft and almost liquid, then wiped on and rubbed in. After a time, the piece is buffed off with a soft cloth. If the wood is sanded nice and smooth, this Beeswax finish leaves a pleasant velvety feel to the piece.
STEP 6: Final Assembly
The threaded bushing is held in place with a light coat of epoxy. Note that the flange of the bushing is on the inside of the cavity so that it takes on the heavy thrust of nutcracking. After turning in the screw halfway, the pressure pad is permanently attached with a strong retaining compound such as Loctite 609. After that, there is no taking the nutcracker apart !
STEP 7: Two Completed Nutcrackers
The author actually made four like these and gave three as Christmas gifts - with a supply of nuts to crack.
STEP 8: A Joy to Use !
The rectangular nutcracker is my favorite !
15 Comments
beanstalklumber 3 years ago
TinkerJim 3 years ago
natantus 5 years ago
TinkerJim 5 years ago
I've decided to go ahead and start on this project. I don't yet have a good answer to the pressure pad but I'm sure I'll figure something out. I'll try to post my version when it's complete. Thanks for the inspiration!
scimsabre 5 years ago
JohnC430 5 years ago
However I need to crack open apricots, peaches, plums and nectarines.... those are too hard to crack by hand. The usual plier type nut crackers also cant do the job. It takes some effort to break them even with a hammer.
kariswg1 5 years ago
Haaah!!!!!!! I just thought of it... just buy a good strong steel clamp and it has all the parts in it to do this without even modifying it....put the nut in the clamp and turn the handle... LOL... Ohh of course you will not have a pretty piece of art work to put on your table. But I am sure your friends will get a kick out of it when you put a bag full of nuts on the table and a few clamps to go around... hahahahahaha
Heyyy, maybe even my big vice will do the job of breaking harder nuts like peaches etc.
SylvanB 5 years ago
I suspect aligning the screw with the grain of the wood might be important to avoid cracking the block, especially with hard nuts.
Lorddrake 5 years ago
attosa 5 years ago
