Introduction: Bookcase / Han in Carbonite Hidden Door
This is a bit of strange one. I got a lot of the concepts from other hidden bookcase door tutorials, but added some twists of my own.
the concept is a bookcase built-in that can swivel to reveal an entrance to a room.
When my home was constructed I saved some money on interior doors by having archways installed. this is pretty cool for open rooms like my dining room and game room, but for my theater not so much. you really need it dark in there to enjoy a movie. In my head I have pondered adding a regular door, but then I saw an instructable for using IKEA bookcases as a hidden door partition and it clicked what I wanted to do.
Objective was to achieve a hidden door look, mix in my love of Star Wars and close off the theater.
Aprroximate total cost was about $150
(little quick edit here, just to be clear it's $150 not including Han, which if it's a DIY sculpt could be a few bucks or for a custom made or even licensed product could be $$$$$. I will hopefully be adding in some info on how to get at least the face casts, like you see on my wall outside the theater)
update: added a vid of the finished product, it also shows the bookcase out of the archway.
Step 1: Determine the Size of the Opening
The size of the opening has a lot of do with the look and operation of the door.
I wanted a built in look, with 3 sections. this allowed me to have the certain bookcase be my "door"
My approach was to find a way to have the bookcases appear to be static, yet roll open when needed.
As you can see in the photo, I have an arch to deal with as well as an opening of about 59"
I decided to get 2 CD towers from IKEA (Billy model) and one 30" bookcase from Walmart.
Step 2: Minding the Gap
Now that you have your bookcases you have to start making some aesthetic choices. In order to have decent clearances I opted to space out th bookcases and use 5.5" boards as trim.
In this pic you can see the bookshelfs are fairly spaced apart, but the boards help to make them look like one piece.
I used angle brackets and put in a board across the top. this helps to stabilize the shelves as well as provide a top pivot point for the center bookcase (which I'll go into later)
Step 3: How to Make the Door "swing"
Okay, here's where it gets kinda tricky. the keys to a hidden door are the hinges have to be hidden. there are a couple ways to handle this, if you door will swing in, you can simply put the hinges on the back. I however wanted my door to swing out so the carbonite block can be seen as you open the door.
What I did was put the whole center bookshelf on wheels. I then mounted thread pipe floor flanges with threaded pipe inserted in them. I drilled a hole in the board I mounted accross the doorway and this allows the bookcase to swing in a fixed arc.
Step 4: Make It Look Pretty
I added some trim here and there. Take note of where the door opens and that your trim doesn't hamper the doors movement. This was a bit of trial an error for me.
Also in my case I mounted the trim to the center bookcase on one side and mounted it to the fixed bookcases on the other. this really helps to conceal the shelf as well as providing the handle to open the door.
Step 5: Drop It Like It's Han
You can just leave the back plain I guess. I was going to put a movie poster frame on the back and make it look like a marquee from the inside, but I happened to have a Han in Carbonite sculpt laying around.
Alright, this piece isn't something you can just come accross. Best I can tell ya is search the net. There is a yahoogroup
http://movies.groups.yahoo.com/group/HICBuilders/
I happened to find someone with a custom sculpt of just the body parts which was perfect for this project. He does not sell em anymore, but on Ebay you can sometimes find the face. the body I think would be an easy sculpt.
I mounted the casting on a thin board and then used bondo and bondo resin jelly to smooth it in and give a "carbonite" look.
Step 6: Get It All Together and See How It Works!
Once it's all together I have to make some adjustments to the trim to make the door swing right.
I also used a black satin finish. The satin hides a lot of imperfections and gaps.
Here's a video of the bookcase during construction so you can see how it works
36 Comments
8 years ago
Is there a master chief helmet on your shelf?!?
8 years ago on Introduction
I want to make my room like that its cool if your room is hidden no one will disturb you and i can hide from my mom and little sister their bit annoying sometimes hey. man can you share me another thing like this because my little sis keep using my computer i hate others using my stuff thanks for sharing :3
Look right here for sculpting
9 years ago on Introduction
interesting
12 years ago on Introduction
is there really no more info you can offer about the body cast?
Reply 12 years ago on Introduction
man, I wish I could tell ya more. the guy I got it from was a flake and fell of the face of the earth pretty much and ended up stiffing some people so I'm lucky I got mine and that was about a year ago. my cast was a thin resin cast with some sloppy work done on it.
Honesty if I had the time, money and skill I'd offer up casts of mine now that i've worked on it a bit.
The yahoogroup is where I got all the info and pics so a start there will get you pointed in the right direction
Something really cool in the world of open source would be a 3D scan of the face on the cast, and a 3D point cloud file (sorry I don't know what the technical name is) so people could sculpt the face with a plastic extrusion printer. I wonder if the actor or his film company owns the rights to the casting of his face?
i like the secret door bookcase idea for a panic room
oh my that is soo awesome :)
10 years ago on Introduction
Love the design on the INside of your bookcase door!! :^)
10 years ago on Step 6
Does it have a magnet or latch to help keep it closed? Or closed enough so there isn't a possible gap?
11 years ago on Introduction
Looks as if the entrance when the door is open is quite small.....
12 years ago on Step 6
I like it!!! the han in carbonite part!!!
This is the most awesome thing I have ever seen.
Could you have rigged this so it opens in? It seems like there would be more room to walk through that way. I really like how you finished the whole thing, but having to turn sideways and crab walk in would be a deal breaker for me. Alternately, what if you did a track, so you could push it back and then slide it to the side, kind of like how you open the side door to a large van? If I were you, I wouldn't go back and wreck my project just to test this theory, but I'm just kind of thinking out loud. My husband wants a "man" room and I think it would be really cool to do something like this to hide the overstuffed recliner and NCAA paraphernalia that he plans on putting in there.
It's possible to do that, but not a really good idea unless you have an existing sliding door well wide enough for a bookcase or you're willing ot cut a huge hole in your wall. It's pretty simple once you get past that part, though. You just need a couple of tracks that met the sliding track to the side in the ceiling, a spring mount on the side opposite the door in a hidden place that will pull the door back into place, and a bookcase that you'd do this to.
big ass christmas tree! nice instructible, really cool idea =D
Very nice, can't wait until I'm out of student digs and into my own place so I can do stuff like this!!
That is exactly what I was thinking!
