Build a TENS Machine to Remove Pain
219,610
98
49
Introduction: Build a TENS Machine to Remove Pain
A Tens machine is used to provide a drug free way of removing pain from your body ( TENS stands for Transcutaneous Electrical Nerve Stimulation )
.Here I will show you how to build your own Tens machine and reduce the amount of pills you use to stop pain .To Build this Tens unit, you will first need to buy a 555 timer IC . The 555 timer is very small about a quarter of the size of your finger nail .You can purchase one for about 25p from Maplins or Radio Shack etc .
There are 2 types of Tens machine. High Frequency Tens uses frequencies in the range of 80 to 100 Hz. This blocks the pain impulses going to the brain .
Low frequency Tens uses frequencies from 2 to 4 Hz . This will help the body produce its own endorphins and increase local blood flow to relieve pain ( this can last for hours ) .
Square waves are universally encountered in digital switching circuits and are naturally generated by binary (two-level) logic devices. They are used as timing references or "clock signals", because their fast transitions are suitable for triggering synchronous logic circuits at precisely determined intervals. However, as the frequency-domain graph shows, square waves contain a wide range of harmonics.
Step 1: Ooop's Statutory Warning
WARNING: The device is not designed for use above the neck or for individuals who have a pacemaker or other heart defects .This device should not be used by pregnant women & Girls .
SQUARE WAVE TRAIN
The “Square wave” permits the frequencies to penetrate the body more efficiently at any given Khz output. Square waves are considered the superior “frequency to wave” output for any Frequency generator device.
Step 2: 555 Timer IC
I first started off placing the 555 timer in the center of the project and then build arround it .
A close up look of the Diagram will show you how the Pins from 1 to 8 on the 555 Timer is connected up . You can use this magnification to reference back to during your project .
Each pin is numbered from 1 to 8 .
Step 3: How the Square Wave Is Generated
The ratio of the high period to the total period of a square wave is called the duty cycle. A true square wave has a 50% duty cycle - equal high and low periods. The average level of a square wave is also given by the duty cycle, so by varying the on and off periods and then averaging, it is possible to represent any value between the two limiting levels. This is the basis of pulse width modulation.
Parts List for a Low Frequency Tens Machine ( Generating the Square Wave ):
(1) 205 K ohm Resistor
(2) 233 ohm Resistor
(3) 5.01 M ohm Resistor
(4) 10 nF Capacitor
(5) 47 nF Capacitor
(6) 555 Timer IC
(7) 28.81ma Light Emitting Diode
(8) Rocker Switch
(9) 9 volt Battery
(10) Thin wire
(11) Solder ( and soldering iron ) or small bread board
(12) Home made conducting pads made with stiff copper wire covered with Foil .
Once all the parts are together you can start to wire up your project.
Step 4: Low Frequency Tens Machine Diagram ( Wave: Asymmetrical )
We are building the Low Frequency Tens Machine at the moment .
Once all the parts are together they should be placed out and wired up shown in the diagram . You could either solder them together or connect them using a very small bread board .
If you find it difficult to see the values in the diagram, these are what they are :
(4) 10 nF Capacitor
(5) 47 nF Capacitor
(6) 555 Timer IC
When you wire up the the Light Emitting Diode, the resistor should be connected to the ( a or + ) Cathode ( the Long Lead ) side of the Light Emitting Diode .The short side connected to the negative or ground side .
Step 5: High Frequency Tens Machine ( Wave: Asymmetrical )
To change your device into a High Frequency Tens Machine, you only need to replace 2 resistors .
Replace the 205 K ohm resistor with a 6.8 K ohm resistor
and
Replace the 5.01 M ohm resistor with a 167 K ohm resistor
(1) 6.8 K ohm Resistor
(2) 167 K ohm Resistor
The 2 red conducting pads shown in the diagram are the silver Foil covered pads to be placed on the body . To increase conductivity you can use hair Jell on the pads . Although you will not cause any damage to the unit, the +/- conducting pads should be kept apart from each other.
Here's a link showing proper placement of electrodes.
http://www.tens-store.com/ems/tensplacement.htm
You could place your finished project inside its own case . Remember to remove the batteries when not in use.
You can simulate this circuit by downloading some software on a free trial . Choose Electronics because the software has a number of Scientific options . Go to :
http://www.yenka.com/
Step 6: A CURE FOR ALL DISEASES ?
To change your device into a medical device to cure diseases, you only need to replace 2 resistors and 1 Capacitor .
Replace the 6.8 K ohm resistor with a 9.6 K ohm resistor.
Replace the 47 nF Capacitor with 100 pF Capacitor
and
Replace the 167 K ohm resistor with a 236 K ohm resistor
Parts List
(1) 9.6 K ohm Resistor
(2) 236 K ohm Resistor
(3) 100 pF Capacitor
This would give an out put of 30 k Hz , to kill parasites in the body, raise the ph to remove acidic environments in the blood . Allow healing Lymphocytes to do their job properly .
The Square wave formula for all square waves is below . You can also visit this website for more information about what your device can achieve . Although their device is out of range of the Low Frequency TENS that you will be building .
http://www.huldaclarkzappers.com/?gclid=CPaXy77zkJwCFZgU4wodj1MCcQ
Step 7: Lymphocytes
Lymphocytes are improved to Kill bad Bacteria within the body , by using electrical stimulation with square waves .
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    • Big and Small Contest
    49 Comments
    PeetW
    PeetW
    11 months ago
    Can I add an LED light to the electrode to simulate the pulse?
    andrewblackie
    andrewblackie
    Question 1 year ago on Step 6
    Can we please have detailed specifications on the parts ie voltage for the capacitors and alternate resistor sizing
    avacadorable123
    avacadorable123
    Question 1 year ago
    need to know the output voltage and current for this. How do you know the frequency when you're using a dc voltage source?
    DanielS1262
    DanielS1262
    Question 1 year ago on Step 4
    Hi, i study medical engineering in Bucharest. Now I work on my own project. I need to stimulate a muscle for the foot drop sindrom. I need 60 V and 10-15 mA. The frequency value is good for my project, but how to generate my tension and my amplitude?
    Thanks for your project, is amazing
    ClownW
    ClownW
    1 year ago
    I have a lot of medical issues and I also recently blew out my shoulder tour of the cartilage all up and crunches when I move my shoulder it's horrifying pain I can tell you a TENS unit really does help I don't understand why other than like this a release of endorphins Etc. By the way for Hertz Works awesome for Rapid pain relief. It also has a distinct property of killing blood-borne viruses and bacteria if you get it over to opposing veins in your wrist. A guy named Bob Beck discovered this a long time ago and I believe by cured a couple of my conditions by doing this I have a dark field microscope made by Nikon and what they say about darkfield skiing and clean blood shows nothing is there absolutely true if you and I did stay in your blood before you start the protocol with the for Hertz it is full of bacteria and all sorts of bed pathogens after about four months of doing this my dark field skins were crystal clear. Anything that cleans your system out like that allows your immune system to work properly. But I got off on a tangent tens units really do work. End of story I am totally convinced I've been using them for years now and they improve my life dramatically
    BillB242
    BillB242
    6 years ago
    I built one of these yesterday. When I place the electrodes on my wrist as a test and then turn on the switch, I got a 2nd degree burn in two small spots from the positive electrode. What can I do to NOT get burned when using this device?
    ClownW
    ClownW
    Reply 1 year ago
    Hey you can buy TENS unit pads for almost nothing on Amazon I got a big packages of them for ten bucks I think might have been even five bucks I can't remember they last for a good long time as long as you keep them stuck to the plastic sheet that they come with. I didn't even take a look to see how old this post was LOL anyway that's my information
    bluetrinityh
    bluetrinityh
    Reply 3 years ago
    Use more conductive materials if you can, like some silver coated electrodes...and the next key step is the electrode gel...you can make your own out of some salt and water...yet best to buy the professional stuff IMHO.
    blainsbrains
    blainsbrains
    Question 4 years ago on Step 7
    Hi, can anyone please explain how this works? I understand the oscillator aspect, but will 9VDC really do the job?
    NicH21
    NicH21
    4 years ago
    What a fascinating post! I had no idea the TENS was so similar in action to the Robert Beck BE device. I think I'll be breaking out my soldering iron for this one. Much respect.
    GregV20
    GregV20
    6 years ago
    How do you generate the high voltage?
    dheerajg1
    dheerajg1
    6 years ago
    not getting output with either low frequency or high frequency device at 9V. What to do?
    aphasic
    aphasic
    6 years ago
    My commercial TENS unit is max 5V RMS, 100Hz, 100us pulse width. Which means the pulses are up to 500V, if I'm not mistaken. However, your device produces only 9V pulses. That's a big difference! I think this circuit diagram looks a bit more promising:
    http://chemelec.com/Projects/Tens/Tens-4a.png
    But thank you for telling us how to cure all diseases! I should try that too...
    aphasic
    aphasic
    Reply 6 years ago
    Actually I think I *was* mistaken, 5V RMS with a 1% duty cycle should translate to 50V peak voltage, since we divide by the square root of the duty cycle. Still a bit bigger than 9V.
    clothier_bruce
    clothier_bruce
    7 years ago
    This Instructable is garbage: here you simply repeat ideas not your own ( low f stimulates release of endorphins and high f blocks signals to the brain ) The evidence for any of this is wafty - what frequencies; what power output; what waveform. Worse, you drag out that nonsense about a 'cure for all disease', first propounded a hundred years ago by a crank called Rife. It was nonsense then and it's nonsense now.
    Stefniamoo
    Stefniamoo
    9 years ago on Introduction
    "This device should not be used by pregnant women & Girls ."
    I get the pregnant women thing. but why not used by girls? why?
    otherwise i like the instructables :)
    saumipan
    saumipan
    Reply 7 years ago
    Not to be used by pregnant (women and girls), that is pregnant women and pregnant girls.
    stimmy65
    stimmy65
    11 years ago on Step 4
    Can I add additional leads from the unit, so that I have 4 pads to apply to the areas instead of just 2 ? And will the electrical impulses be cut in half ?
