Build a Letterpress & Use It to Print Things
282,261
444
45
Introduction: Build a Letterpress & Use It to Print Things
Shortly after getting engaged, it became clear letterpressed save-the-dates, invitations, rsvps, & thank you notes were in my future. After a bit of looking around at commercial letterpress, as well as used presses, it also became clear these things were not in the budget. What to do? Build a letterpress and print the things on my own.
I started by looking at letterpress designs at briarpress.org, and, it seemed to me anyway, the basic functioning of Gutenberg's model could be relatively easily reproduced on a small scale and a small budget.
Of course, it ended up taking a while, but the invitations got out on time.
Step 1: Construction
OK, unfortunately, I didn't take pictures as I built the thing, and I'm not going to take it apart or build another, but, looking at the finished product, I think the it becomes pretty apparent how you'd put one together.
What will you need? These things:
Materials
1. Two 4'x8' sheets good quality 3/4" plywood (find stuff with relatively few gaps, there's going to be a lot of pressure involved in this).
2. Six 18" lengths of 1/2" diameter all-thread ( I think I found 36" lengths and cut them in half with a hacksaw; if you do this, be careful not to screw up the thread too much when cutting).
3. Nuts & washers to fit the all-thread. You'll need a total of 24 of each. It was cheaper, if I recall correctly, to just buy a box of each.
4. A veneer press screw. I used this one.
5. Some cork board. I found 12" square pieces in a six-pack at Ace.
6. Wood glue & a couple of wood screws.
Tools
1. A table saw to deal with the plywood
2. A drill press (with relatively long 1/2", 11/16", & 1" bits)
3. Various pliers, wrenches, maybe a hammer, a glue brush, etc.
Skills
1. The ability to divide & multiply fractions (I'm sadly lacking here).
2. The ability to measure relatively accurately (this, I can do).
Notes:
1. This is scalable. Make it bigger, make it smaller. This version has a maximum press area of 12"x12" in theory, and probably a little less effectively. There are bigger, heavier duty press screws out there that would probably be appropriate if you went up to something like 16"x16".
2. A lot of this, especially as we move toward the actual printing, was engineered on the fly. It works for me, but I'm sure there are better ways to do some of this. Fix it up.
Step 2: Construction Details
Closeups. Note that, though I tried to get everything centered when drilling for the all-thread, I missed the mark a little. Inexactness in execution is countered by overzealousness in design.
Step 3: Don't Forget the Platen
In letterpress terminology, the platen is the piece that does the pressing. You'll be needing one. I got the base and upper bar out of a single 4'x8' sheet of plywood. With the second sheet, I made the platen.
From a sheet of 3/4" plywood, cut seven 12"x12" pieces; glue them together to form a 12"x12"x5&1/4" block.
Not that the platen is free-floating, rather than actually attached to the press screw somehow. Originally, I had planned on attaching it, but the press screw was not pre-drilled, as I assumed it would be. It's for the best. It would be difficult to ink the type if the platen were in the way.
Step 4: Print!
OK, you've got the thing built now. There's a good chance you're wondering how on Earth you'll do anything useful with it. That's what happened to me, at least.
What are you going to need to print?
Materials & Tools:
1. Something from which to print. This will most likely be one of two things, either a photopolymer printing plate, or else a case of letterpress type (or, potentially, some linotype you have a shop set for you). If you use type or linotype, which is what I originally intended to do, you'll need some sort of a chase to set it in (I imagine you could make one from plywood), and a way to mount that chase to the base of the press (my plan was to drill matching holes in the base and chase and use dowels to hold them together). You'll also need all the basic type-setting tools, and, presumably, patience.
I ended up going the photopolymer plate route. There are a few places you can get them on-line. Mine came from Boxcar Press. Send them a to-scale pdf of your art, and they'll send back a plate for a reasonable price. If you use them, I recommend ordering the "deep relief" plates, as it makes inking much easier. Boxcar's plate are adhesive backed, so you can stick them directly to the plywood base.
2. Some ink. You can get ink made specifically for letterpress applications. Because I put off the purchase, I went with block printing ink, which I could get locally. It's not ideal. I ended up thinning it out with a bit of Turpenoid. I've never used letterpress ink, but it's probably a better consistency for this type of printing, so you should probably get some.
3. A brayer, and something on which to roll out the ink. Speedball brayers are readily available, and, from what I can tell, of relatively low quality. Mine is just slightly uneven, which makes inking the plate something of a pain in the ass. A big sheet of glass or plastic, anything smooth and non-porous, can be used to roll out the ink.
4. A mixing knife or equivalent, thinner, etc. I found cotton swabs handy for cleaning up stray ink on the plate. You'll also need some scrap mat board.
So, you've got your plate. Stick it in the middle of the press bed, and let's get talking registration.
Step 5: How Is This Supposed to Line Up?
So, registration is one of the things I figured out on the fly. Like I said earlier, this works, but there've got to be better ways to do it. I'll break this up into a few steps. The first two are illustrated in the photos below.
One thing you'll need to do beforehand is take a sheet of corkboard, center it on the press bed, and use something (I used the little sticky felts for the bottom of furniture legs) to line the edges, so that it can be placed in the same position on the bed easily and reliably.
1. Take a piece of the paper on which you'll be printing, apply double sided tape to one side, and carefully line it up on top of your plate (or type, or whatever).
2. Carefully, carefully, so as not to shift the placement on the paper on the plate, place one of the sheets of corkboard on top of the paper & plate.
Step 6: Press & Remove
Now that things are in place, it's time to press. To do this, you'll
1. Pick up the platen and place it on top of the corkboard.
2. Crank down hard on the press screw. Really, crank until can't crank no more.
Once you've done that, loosen the press screw, remove the platen, and pick up the corkboard. The paper will now be stuck roughly in the middle of it.
Step 7: Where Is My Xacto Knife?
Now that the paper is stuck in the right spot, you need a way to get every other sheet of paper reliably placed in that same spot. Here's what I came up with:
1. Cut a few slits through the corkboard around the paper.
2. Grab the Book Darts from the office.
3. Bend the Book Darts and slip them through the slits in the corkboard so that they'll act as tabs to hold the paper in place.
4. Place a little scotch tape around the edges and corners of the paper; this will help when fine tuning paper placement.
Step 8: Inking & Printing
Getting close here.
1. Use the scrap mat board to make a little frame that fits around the plate. This will make inking much easier.
2. Roll out some ink.
3. Slip a fresh piece of paper into the tabs on the corkboard.
4. Ink the plate and remove the mat board collar.
5. Paying mind to the little felt things, carefully place the corkboard over the inked plate, paper side down.
6. Place the platen on top of the corkboard and press (I usually let the pressure sit on the paper for 15-30 seconds, or enough time to sip a little beer).
Step 9: And...
Now you've got a print. Repeat the last few steps a hundred & fifty or so times, and you'll have yourself a respectable edition.
*After some screwing up, and have no doubt about it, there will be some screwing up, I got to the point where I could get a consistently good print every minute & a half to two minutes. It does take a long time, but you save a lot of money, and you get to do it yourself.
1 Person Made This Project!
  • Game Design: Student Design Challenge
  • Big and Small Contest
  • Make It Bridge
    Make It Bridge
45 Comments
TPST
TPST
4 years ago on Step 1
Thanks a lot for posting this post, Your post has always been an informative source for me.
Cool DIY Letterpress machine.. How about printing result, same with commercial type?
all thumbs1
all thumbs1
10 years ago on Introduction
Thank you . I went to home depot with my friend and they argued with me that I could not do this on and on . Because I could recall the name of the veneer screw both men at home depot decided what I needed and should buy. How frustrating when I know what I want but not the proper names. Too bad . I downloaded your instructions and I will show them exactly what I want and . Yes it can be done.
sarahgch
sarahgch
12 years ago on Introduction
I have't done letterpress, but I have done lino block printing and I used to just make registration marks for the plate and paper underneath where the plate was placed. (I would draw or tape a rectangle for the plate, then a larger rectangle for the paper, and then put the plate down, then the paper) So I would just place the paper over the inked plate and then run it through the press. Could I do it that way with this press, or do I really need the little tabs to hold the paper to the press while printing? Does it do some major shifting or something?
Also, for the top part, where the press screw is- could you just stack the wood? Or does it have to be vertical? I don't have the long drill bits, so I was thinking it would be easier to drill through the boards one at a time and then stack them. But maybe that wouldn't work, if it has something to do with weight resistance.
Thanks for this, by the way. I am SUPER excited about making it. I need to make some invitations too!
uncre8d1
uncre8d1
Reply 11 years ago on Introduction
as a woodworker: stacking the top bar layers horizontally would be much stronger, taking advantage of the plywood's cross-grain strength. HOWEVER, this construction method *requires* you to have a press screw that can be taken apart. If you can't remove the handle, you'll never get it through the hole you drilled. It doesn't really say in this project, but if the screw doesn't break down you could build the letterpress per this instructable and cut a notch through the center layer of the top bar before gluing the top bar together. I'm in the initial stages of this project, so hopefully I'll have some more information in a few days.
lwestbrooks
lwestbrooks
You say you got everything out of two sheets of plywood. Plywood comes in 4x8 foot sheets. I calculate that you can cut 4 pieces 12x16, 6 pieces 4x16 and 7 pieces 12x12 with less than one sheet. Have I missed some of the instructions?
uncre8d1
uncre8d1
I haven't figured it out for 4'X8', since my Home Depot is unable to stock anything that I actually plan on using and I have to use smaller pieces - so forgive me if you've already done this, but what people often forget in calculating material is a) sawcuts each take out 1/8" and b) make sure you draw it out before buying, so you can be sure that the A" x B" piece you're counting on can all be cut from the same place.
murphis
murphis
Hi,
I'm going to build mine this weekend, have you already built yours? Did you find that you only needed the one sheet of plywood? Just wondering.
Thanks!
murphis
murphis
I'm so impressed with your skills! And sense of humor about the process. So much so that I'm going to make the letterpress for my holiday cards. A couple of questions before I start:
what paper stock did you use? I've been told Crane 100% Lettra 110 lb cardstock is good, but they also have a 220 lb cardstock. Any thoughts?
how may colors did you use on a single piece? if you used more than one does that make it more difficult or just more time consuming?
Thank you in advance for you help.
Murray
hamad2
hamad2
11 years ago on Step 9
Thank you for the idea
dylanwhat
dylanwhat
I built a letterpress based on this design, although I modified it to use a two cartridge system that avoids fiddling with the platen which rides up and down with the press screw. Check it out http://www.youtube.com/watch?v=ALGGwPKKkCc
crazyg
crazyg
12 years ago on Step 9
i got a cast iron one of those presses out of a skip,i painted it green and yellow. still slightly baffeled be a bookdart,but iv got a photocopyer so im probably ok,(heavier balls on spinny clamp bit at top make it self tightening,give it a shove and it steadly spins down giving a uniform grip each time,shame i use mine as a vice.
smjessica135
smjessica135
The main reason behind the decline of the letterpress printing technique was the advent of more advanced & efficient printing presses like the Offset Printing Machine, lithographic press or the flexographic press. But it is really interesting to know that letterpress printing technique is still alive and letterpress printing machines such as rotary printing machines, rotary letterpress printing machine is now available with all latest features.
purpleshiny
purpleshiny
13 years ago on Introduction
It's possible to use a lasercutter to etch a relief plate rather than getting a photoplate made as in this example... I'm not sure whether Ponoko's service will cut deeply enough or not. It should also be possible to use a chemical etching process on metal for this, but I haven't tried that :)
gregr
gregr
Reply 13 years ago on Introduction
Typically if you want to print with an etched plate you would use an intaglio press. I would be worried about breaking the laser cut Ponoko plastic by putting it into a press like this...
metalfury
metalfury
13 years ago on Step 9
Thanks for the instructable. Inspiring and I'm looking foward to having a go!
strangerousanya
This is fabulous--I'm thinking about doing this for my wedding this fall too! I'm curious, did you also do envelopes? If so, were you able to prevent the impression from going through to the back? And what kind of paper did you use? Thanks!
freezemom
freezemom
I have been working in a commercial printing company. We open the envelopes and print on the flip. Just watch your impressions! Letterpress is my favorite of all our print processes!
khadgapa
khadgapa
14 years ago on Introduction
I have found this DIY letterpress very inspiring and am about to make my own to print wedding invitations for myself. I am just wondering how you handled the paper? Which paper did you buy? Did you have to cut it yourself? If so, how did you cut it and what tips do you have about that? Thanks for taking the time to document this enterprising homemade press.
kretzlord
kretzlord
14 years ago on Step 5
could you just attach the corkboard to the platen? some super 77, or even awesome double stick tape?
