Introduction: Capelo HW
This is one of the tutorials that I like. I am a big fan of cars and I have a large collection of scale cars, but I am one of those who like to take them out of the package and see them.
So I designed a capelo which had a standard size where I could put HOTWHEELS, MATCHBOX and some of CARS. I also wanted them to be assembled so that I could put them together so that I could exchange them.
MDF 3mm.eps
MDF 3mm.pdf
MDF 6mm.ai
MDF 6mm.eps
MDF 6mm.dwg
MDF 6mm.dxf
MDF 6mm.pdf
Acrylic.ai
Acrylic.dwg
Acrylic.dxf
Acrylic.eps
Acrylic.pdf
Hoja de fomi.ai
Hoja de fomi.dwg
Hoja de fomi.dxf
Hoja de fomi.eps
Hoja de fomi.pdf
Master sheet.ai
Master sheet.dwg
Master sheet.dxf
Master sheet.eps
Master sheet.pdf
MDF 3mm.ai
MDF 3mm.dwg
MDF 3mm.dxf
It is required to cut the files in laser cut (Attached file).
MDF 3mm (File Attachment)
MDF 5.5mm (File Attachment)
Acrylic 2mm (Attached file)
Fomi (File Attachment)
UHU glue
White glue
Acrylic glue
Scalpel
Step 1: STEP 1
Using the glue in UHU we glue the fomi to the 5.5 mm MDF, this will serve to have the base of our cars, that they do not move freely in the capelo and at the same time the MDF will help us to close the capelo.
Step 2: STEP 2
Using the white glue we glue the two pieces of 5.5mm MDF, taking care that the engraving is on top.
Step 3: STEP 3
Using the white glue again, we join the 5.5mm MDF with the 3mm MDF base using the engraving as a guide
Step 4: STEP 4
>>>> Be very careful in this step <<<<
Use the acrylic glue to stick the capelo, but be careful not to stain the acrylic, I recommend using a syringe.
Step 5: STEP 5
Measure the car at the base of the fomi, and with the help of a scalpel remove the squares that match the tires, this will help us to prevent the car from moving inside the capelo.
Step 6: FINAL
Finally Repeat these steps until you have all your cars protected and it is time to arrange them and play with the pattern
Enjoy
