Cheap Drill Press DIY
44,556
438
7
Introduction: Cheap Drill Press DIY
I decided to build a drill press for 12$.
I have mostly used design by Izzy Swan he have pretty good build videos: His YouTube Channel
Here You can see the video of my final product : https://youtu.be/Ogf9JVEOmrY
Now I can drill bunch of 90deg holes.. but why?
Thank you,
Step 1: Materials and Tools
Materials:
1.Use your old corded drill or buy the cheapest one:
Example HF coupon for 12$ Drill: coupon
2. hose clamp
3. Scrap wood
4. Wood Screws
Tools
1.Table Saw (Can be done with a any saw, but have to changed little bit).
2. Drill.
3.Safety Glasses.
Step 2: Aseembly
Create a slide by sandwiching wood pieces together.
Use paper as a shims between the wood.
Wax the sliding surfaces.
Step 3: Assebbly
Secure the drill into the sliding carriage.
Take a square and make sure that the drill bit is 90deg to the surface. Use wedges if needed.
Add Handle and a spring to allow better pushing and returning.
Be the First to Share
    • Rice & Grains Challenge
    • Lamps Challenge
      Lamps Challenge
    • CNC and 3D Printing Contest
    7 Comments
    kukopia
    kukopia
    5 years ago
    All to vague to be of any use
    Yomismo62
    Yomismo62
    7 years ago on Introduction
    Hello you can clarify complementing your project, such as holding the drill. Since in all three phases you have here, no clarifies
    sagariwa
    sagariwa
    thanks. you've been very helpful with your photos and description plus the link to the video. til the next project then.
    Elliot Lord
    Elliot Lord
    It looks good but there aren't any real instructions to follow and it looks quite complicated.
    handroid7
    handroid7
    Thank you,
    The reals instructions are:
    You need to take a look at your drill..make a holder for it.
    You need to buy/make sliding mechanism.
    Attach them together :)
    Its pretty easy to make.. hard part is to alight it and also make it stable.
    handroid7
    handroid7
    Thank you,
    Its not as good a store bough drill press .. but than i good enough .:)
