Introduction: Cold Frame Construction With Recycled Materials
Here is an example of how to construct a cold frame for your garden using recycled materials. You can build a cold frame without spending a dime and reduce landfill waste at the same time.
Step 1: Gather Materials
a) discarded wooden window
b) scrap pieces of wood (long enough for each side)
c) screws and nails
d) hinges
e) tools (saw, drill, hammer, measuring tape, pencil)
Step 2: Measure
Step 2: Measure
a) measure window dimensions
b) measure wood to match windows dimensions (to create a rectangular frame)
Step 3: Cut Wood for Frame
Step 3: Cut wood for frame
a) cut along pre-measured lines
Step 4: Assemble Frame (base)
Step 4: Assemble frame (base)
a) form a box with the 4 pieces of wood that have been cut
b) fasten each side together with nails
Step 5: Assemble Window Lid
Step 5: Assemble window lid
a) place window on frame to create a lid
b) fasten hinges to base and window (use screws)
Step 6: Put the Cold Frame to Use!
Step 6: Put the cold frame to use!
a) place on prepared ground in a sunny location
b) plant winter vegetables such as herbs and lettuce
c) harvest and enjoy!
6 Comments
8 years ago on Step 6
That kind of wood would be better if you painted it.... But you did a great job...
11 years ago on Introduction
so.. years ago i DID the old recycled window over my large garden bed... then a 35 ft. pine tree fell over during a storm, and smashed it into a million pieces. i now have a raised bed with glass deep inside, and glass shards all over my garden. every year i dig more out: it is never ending.
so, i'd have to say check your surroundings before considering glass in the garden!
12 years ago on Introduction
I have a 6x4 raised bed. It looks very similar to your design sans the top. Could i use it as a cold frame particularly for starting seeds in the spring? I have not ever seen them designed alrge like mine and i was wondering why.
Reply 11 years ago on Introduction
That sounds like a good idea.... I haven't seen it done in that way before, but it should work. You can always use several windows to cover the bed or create your own out of wood and plexiglass. It would be a good idea to make the windows easy to remove during warmer months to allow the elemnts to purify the soil. A good resource for building cold frames is Four Season Harvest by Elliot Coleman. Good luck! I am curious to hear how it turns out :)
nice project
If you line the inside with polystyrene sheeting it will stay warmer and keep frost out and use white will make it better for light.
The bigest problem i have i can never make enough :)
http://www.gardenersworld.com/how-to/projects/cold-frame-insulate/
Reply 12 years ago on Introduction
Thanks for the information.... great video :)
