Introduction: Crayon Plushie
This is a cool little project to do when your board and u want to do something and the result is pretty cool to!
Step 1: What You'll Need
You will need...
{1}-2 sheets of some type of fabric... Any color (I used felt)
10cm by 13cm.
{2}- 2 sheets of fake leather or fake leather like material 9 by 9.
{3}- thread- color of your choice
{4}- stuffing or fluff and a marking pencil
Step 2: Step 2
Now take the yellow fabric and sew the ends together into a tube (make it however wide you want it.) And cut of the access fabric that you don't want.
Step 3: Step Three
Take the (color of fabric u chose) that u have left and cut out a circle that fits to the end of your tube (whatever end you want.)
Step 4: Step Four
Now you should have just enough fabric to make the tip of the crayon. Cut a strip that is as wide as you want it to be and as long as the width of your circle you chose to start the crayon ( a funnel shape). Now sew it into a circle with a skinnier top and the width of the rest of the crayon top and add it to the top of the crayon that has a empty whole. Which is extending the top.
Step 5: Step 5
Now that that's done there should be a tiny whole at the top of the "crayon" insert the stuffing then cover it up with the right amount of fabric cut into a circle.
Step 6: Step Six (optional)
Now this part is optional....
Take the leather like material you chose and cut it into 3cm wide and however long the width around your crayon is. And I used a special fabric whole puncher thingy to punch stars into it but you choose if you don't want a design now hand sew it the the crayon at the end and near the tip
Step 7: Step Seven
Now for the last step Write the word crayon On a piece of paper.Now cut out each letter and pin it to the fabric and trace the outline if the paper then cut it out and sew it to the crayon.
