Introduction: Crochet Flower Arrangement
If you are looking for a quick and easy gift for a loved one that is both simply but meaningful here is an idea for you.
Materials for the Rose's
- Red and Green colored yarn
- 4.5mm crochet hook
- Scissors
- Hot glue gun
- Wooden skewers
Materials for the lavender's
- Dark purple and light purple colored yarn
- Scissors
- Hot glue gun
- Wooden skewers
Materials for the sunflowers's
- Yellow and Brown colored yarn
- Pillow stuffing
- Scissors
- Hot glue gun
- Stitch marker
- Wooden skewers
Step 1:
Round 1:
Start with a slip knot.
Chain 48.
Add one more chain this is our "turning stitch"
Step 2:
Round 2:
Your going to go into the 2nd chain from the hook, and in each chain you are going to do a "HDC" which stands for a half double crochet and you and going to do that 48 times
- For the "HDC" you yarn over insert into your hook then pull through the first loop on the hook then yarn over and pull through all three loops.
Step 3:
Round 3:
Chain 2
Flip the project
The you are going to do 3DC, skip a stitch (repeat all the way down)
- For the "3DC" you are going to yarn over pull though then yarn over pull though two and then yarn over and pull though the last two
Step 4:
Round 4:
Chain 2
Flip the project
Chain 1, Dc, 2 Dc, Dc, chain 1 slip stitch (repeat all the way down)
This process is to create the petals on the flowers
And as you can tell it is already starting to curl witch helps for when you have to wrap it around the wooden skewer.
Step 5:
Round 5:
Now we are going to start with the bud of the flower
Start with a Magic ring/circle
6 HDC into the magic ring and then tighten together
Step 6:
Round 6:
Slip stitch chain 6
Slip stich, sc, hdc, dc, dc
Then go into the next stitch and repeat all of these steps all the way down
- "sc" is single crochet
- "dc" is double crochet
- "hdc" is half double crochet
Step 7:
Round 7:
And now that the rose and the bud are done you can glue them together.
Start by gluing the side first and then rolling it around and then with the little hole in the middle of the bud you can insurte the stitch that has the flower already on it and after glue the leaves around the rose.
And then once you have glued then together your going to wrap green yarn around the wooden skewer.
And there you have a rose.
Step 8:
Round 1 of the lavander:
Chain 58
Step 9:
Round 2:
In the third chain from the hook you are going to do 3Dc , chain 2, slip stitch.
Into the next stitch: slip stitch, chain 7, slip stitch back into the first slip stitch. And we are going to do that all the way down.
And then with your green yarn you are going to wrap it around the wooden skewer and then once you have done that you are going to wrap the part of the lavander you made around it and there you have a lavender.
Step 10:
Round 1 of the Sunflower
Magic ring, ch 1, 6 sc (6)
Pull the shorter end to close the circle
Step 11:
Round 2:
6inc (12)
increase(inc)= 2 single crochets in 1 stitch
insert your stitch marker after doing the first single crochet
Round 3:
6 x (sc, inc) (18)
Round 4:
6 x (2sc, inc) (24)
Round 5:
6 x (3sc, inc) (30)
Round 6:
6 x (4sc, inc) (36)
Round 7:
1sc in each stitch (36) And after you are done with the 36 stitches you close it of with a slip knot.
R1-R7: same as the seed part sepal is the exactly like the seed part, just in different color
Step 12:
1 petal: (ch2, 1dc, 1tr, 1dtr, ch2) in 1 stitch, ch2, slst, (1dtr, 1tr, 1dc) in 1 stitch, ch2, slst
- Ch is chain
- Dc is double crochet
- Tr is triple crochet
- Dtr is double triple crochet
And do this all the way down
Before doing the last pedal make sure to put in the stuffing.
Step 13:
To finish of the sunflower you are going to wrap a wooden skewer with green yarn and then attach the skewer to the flower.
And there you have a sunflower.
