Introduction: Cross-stitch Pattern in Photoshop (with Symbols!)
This is how to make a cross-stitch pattern with symbols representing colors in photoshop!
First we will prepare your original image by lowering the resolution, so that one pixel represents one cross, and lower the number of colors so that you can use a limited number of yarns.
Next we apply the grid.
After that I will show you how to replace individual colors with symbols.
This is good because you can print the pattern in black and white, and also because you can see the difference between similar colors.
This technique can of course be used to make decorations and gifts for the holidays, and other occasions!
Update: Here are two examples. The mario image has 5x5px square size and my complete bird montage pattern has 20x20px square size ( full size color, full size symbols)
Step 1: Resize the Image
First, of course, you crop the image so that you have an original that you want to use. Auto-levels and auto-contrast is always nice as well, and best to do before downsampling.
One way to lower the resolution is to use the filter "Mosaic". This is fine, but I don't really like it because it limits my control over the size of the final pattern. A much better way is to just resize the image to the desired number of stiches you want the final result to be (that way you also limit the number of total resizes to the image).
So,
Measure the fabric and count the number of stitches you want the result to be.
Resize the image to that number of pixels
Then, resize it up again with 500% (I use 5px per square). Remember to use the "Nearest Neighbour" setting to preserve the edges. We want those!
Update: When resizing down the image, the only thing you are interested in is how many stiches wide and high your final product should be. Just insert those numbers in the "Pixel dimensions" (if it's greyed out, check the "Resample image" box). The resolution and document size makes no difference here.
Step 2: Index Colors
Now you want to reduce the number of colors. There are two main ways to do that, and the different techniques have different results depending on the original image.
The first way is to change the image mode to "Indexed Color" and limit the number of colors. Play with the number of colors and the dither settings to see what results you get with the different values. The key is to get the highest quality possible with the lowest number of colors.
Update: When you are satisfied with the result, you'll have to change back to RGB color mode to be able to do the last steps. The colors have already been discarded so now you can work in RGB mode.
The other way is to use the Posterize filter. Same here, try different numbers and see what you get.
You could also start by making a custom palette with the yarn colors you have availiable and choose that palette in the "Indexed Color" dialog... Maybe more applicable if you are using beads
(The mario image already had the perfect number of colors so no need to change anything there)
Step 3: Make the Grid
The first thing to do here is to define a grid pattern. I used 5px squares, and I want every five lines to be heavier, so I made a new document with 25x25px, and drew four gray lines and one black in both planes. Remember to use a transparent background. Then define it as a pattern.
Now make a new layer above the original and fill it with your new grid pattern. Choose the Paint Bucket Fill Tool and select "Pattern" in the drop down, and use your new pattern. Then just click in the new empty layer to fill it with the pattern!
Next, you want to merge the grid layer and the original image layer.
Nice huh?
You could be satisfied here, but I am not. I once wanted to make a pattern out of a grayscale image using black, white and two shades of grey, but the greys were to hard to tell apart, so next I will explain how to replace colors with representing symbols. (also I have no color printer)
Step 4: Replacing Colors With Symbols
Here is a good place to make a copy of your result. You will need it to identify the colors after they are replaced!
The first thing to do now is to define a few patterns to replace the colors with. They should be 5x5px and use only the top left 4x4 pixels, if you made the grid pattern the same as mine.
Next, make a new layer and place it behind the original image.
Fill this layer with one of your patterns.
Now, using the magic wand, select the color you want to replace (without Anti-alias, and with Tolerance 0 and non-Contiguous).
Clear the contents of the selection (delete/backspace) to let the pattern shine through.
Last but not least, you need to merge the two layers.
Now, repeat this with all the colors you need to replace and you are set!
If you want it to look better you could easily use bigger squares from start, and make a wider grid and symbols, but this is good enough for me.
That's all for now! Post your home made patterns in the comments so we can se what you do!
Check out my instagram Restitch where I cross-stitch pixel characters on second-hand tapestries.
44 Comments
2 years ago
Was kinda hard to understand at first and wish the instructions were easier to follow but I got it to work and I am super happy someone had a write up like this, so thank you. It is appreciated!
Reply 2 years ago
That's great! This tutorial is 12 years old, so I'm happy it is still usable at all 😅
Question 3 years ago
I can't seem to figure out the symbol part. When I add them, they don't line up properly. Can't seem to get this tutorial to work out for me
Answer 3 years ago
If your symbol pattern is the same size as your grid, they should repeat correctly. Make sure to leave a pixel in the pattern that will be covered by the grid. If the grid size is 5x5, a circle symbol should be 4 pixels large. The 5th pixel will be covered by the grid line. Depending on how you made the pattern, you might need to move the pattern layer a pixel or two to align the symbols and the grid.
3 years ago
You can check also out this cross-stitch Photoshop effect tutorial
http://www.psd-dude.com/tutorials/create-a-cross-s...
5 years ago
When I make a pattern using this tutorial, the colors don't always end up using solid squares of a grid. Is there a way to correct this short of going in and manually correcting each grid square?
Reply 5 years ago
Hi!
If I understand you correctly, the grid pattern is not aligning correctly with the squares of the upscaled image. This could be for two reasons (that I can think of).. Either the size of the grid does not exactly match the scale of the image. If the grid has 5 pixel squares (icluding the grid line: 1px gridline and 4px transparent), the subject should be resized with 500% etc. Another option is that the grid pattern should have the gridlines top and left, or bottom and right, so that it covers change between colors.
If you have a grid pattern in a separate layer that does not align, you can move the whole pattern by pressing ctrl + arrow keys until it aligns.
5 years ago
Could you add more detailed instructions for how to apply the grid pattern to the picture? I created the grid with no problem, saved it as a pattern as well. I just can't figure out how to add the pattern to the layer. There's no option for doing that when making the layer, and I tried applying it via the effects, pattern overlay, and could find the pattern, clicked on it, but it didn't show up anywhere accept in the effects box.
Reply 5 years ago
This is done with the fill tool. I have updated the instructions with some details!
Reply 5 years ago
Thank you! I did it! :-)
6 years ago
In the interest of calculating how much thread to buy: is there any way of counting how many there are of each symbol?
Reply 6 years ago
It should be possible! If you keep a copy of the image in the original size (where one pixel is one square), you can use the magic wand tool to select all pixels of a single color. Then I found this instruction for the number of pixels selected:
"Go to Image > Histogram. It will tell you at the bottom the number of pixels in the current selection, or the whole picture if none are selected."
You could also do this in the resized version of the image, and divide by 100 (for a 10x10 grid).
Reply 6 years ago
Thanks. I think I tried this early on, but I kept getting wrong answers (not that it won't work, I'm just new to photoshop and probably missed a setting somewhere). I ended up finding a count tool. I was just really confused because I kept getting the same number of pixels for nerely every color. It turns out photoshop runs out of fingers to count on at a fairly low number. I ended up dividing my pattern up into several smaller chunks and using the count tool on each of them. It was tedious, but doable. The count tool is under image -> analysis -> select data points -> uncheck everything but count -> wand select the color -> image -> analysis -> record measurements.
6 years ago
Do you have to buy the premium first to do anything. I have clicked download a couple times and a popup comes up asking me to buy premium when I say no thanks it doesn't do anything else. I don't mind buying if it does what Im hoping it does. and I can figure it out.
Reply 6 years ago
Hi! I think you can read the thing without premium, but they (instructables) seems too have PDF download as a Premium feature..
6 years ago
Wondering if there is analog to this process in Corel PaintShop Pro Photo X2. Can anyone help?
6 years ago
Thank you! Thank you! Thank you! My sister had her eye on a cross-stitch kit that was $150. I bought the thread for $15 and then made my own pattern.
Tip for the person with the big pattern: I just made a 10x10 grid - with wider lines on the very top and very left lines - then filled a layer with the grid design the same way you do for the symbols (but on the front this time).
Also, I was getting kind of symbol blind by the time I was done. At the end, I added a new layer with the original color blocks, set it to black and white, and set it to 50% transparency. You could merge the two layers, but I kept it separate in case I wanted to turn them on and off separately.
The custom shape tool has some nice presets on patterns, too.
6 years ago
I'm STUCK on the last step. I get to the part of selecting the color I want to replace, and select it, and then from there I don't know what to do. The next step reads to merge the two layers. I do that and things don't look any different. My color is still there and I don't know where the pattern goes. Please help (I need step by step and where to find the buttons). My Photoshop is CS4
Reply 6 years ago
Hi! Have you created a layer behind it filled with the pattern? In that case the only thing you need to do is to select the color using the magic wand, and then press delete to remove that color, letting the pattern shine through instead. After that you merge.
Reply 6 years ago
I see now that this is missing from the instructions. Adding it now! Thanks! :-)
