Introduction: Custom Tile Coasters
Want to customize a Holiday gift for someone special?? Here ya go! Custom Coasters!! The video tutorial shows you how to complete this using vinyl cutouts. If you want to try this at home - here is are a few different ways. LET'S GO!
Step 1: Gather Supplies
You'll need coasters. I got mine from Menards for .30. You can create a set of 4 easily!! You'll also need wet glue, a paint/foam brush, felt pieces, clear sealer (I'm using fast drying polyurethane) to finish - if you don't have this you can use Mod Podge. Finally you'll need die cuts, vinyl cut-outs or a sharpie!
Step 2: Finish Up
If you're using die cuts:
1. Add a tiny bit of wet glue to adhere your diecuts to the coaster and let dry
2. Once your die cut has dried - add Mod Podge or Clear Sealer on top of the entire coster - let dry
3. Add some felt to the bottom of the coaster to prevent scratching the surface where it sits.
If you're using Vinyl:
1. Adhere your vinyl to the coaster (see video)
2. Add Mod Podge or Clear Sealer on top of entire coaster and let dry
If you're using a Sharpie:
1. Draw your desired shape, name or design on top of the coaster - let air dry
2. Add Mod Podge or Clear Sealer on top of the entire coster - let dry
