Introduction: DIY Crush Bleached Jeans
The bleached denim trend is still kicking and looked easy enough to tryout on a pair of jeans that needed some reviving. With a little inspiration from some Free People jeans I've seen, I decided to experiment with studs to give them more of the rock-and-roll look.
In this instructable I'll show you how to bleach a pair of jeans and also add some metal studs.
This is a really easy project, but definitely worth practicing a few times before trying this on your favorite jeans.
Step 1: Materials
1 pair of gloves
1 bucket
1 pair dark jeans
2 rubber bands
1 large bowl or other liquid container
1 bottle bleach
1 measuring cup
Water
1 bucket
1 pair dark jeans
2 rubber bands
1 bottle bleach
1 measuring cup
Water
Step 2: "Crush" Your Jeans
Take your jeans and ball them up.
Then use the rubberbands to keep it in a ball shape.
Place the jeans in the bucket.
Step 3: Mix Bleach
Put your gloves on.
Mix 1 part bleach and 4 parts water in the bowl before you put it in the bucket (this is probably unnecessary).
Then pour over the jeans into the bucket. Add enough bleach/water mixture to cover the jeans. I ended up using about 5 cups of bleach.
Step 4: Wait and Observe
After an hour, check the progress. My jeans took about 2.5 hours.
I checked on them by moving the rubberbands or pulling them apart a bit to see if there are signs of color change.
Different jeans, take different amounts of time. I tried 3 different types of jeans before these, and had pretty diverse results.
Step 5: Wash and Wear
Once you see the desired color results, take them out of the bleach bucket and rinse as thoroughly as possible. I used the rinse only cycle on my washing machine, but you could also rinse in the sink or tub.
Then put the jeans through a complete wash alone.
