Introduction: DIY Halloween Cement Jack O' Lantern
Oh Halloween, what a fun time of year. And on a year I don’t have a Halloween costume party to go to, I’ve got the time and energy to put into decorating. Being a maker of all things cement, I thought I would try to create a cement Jack O’ Lantern.
Did you know the Jack O’ Lantern comes from a mythical ghostly Irish figure?Some guy nicknamed ‘Stingy Jack’ tricked the Devil a few times. And when Jack passed, God didn’t want him in Heaven. So the Devil got revenge by not letting him into Hell and made him roam the earth in the dark with a single burning coal to light his way. Who knew? I’m sure there’s a couple of lesson’s in there somewhere. ;o]
I really wasn’t sure how this would turn out and thought there might be a good chance this would go on the ‘Project Failed’ list, but it didn’t! It only took two tries to get it right. However, the first try also turned out really cool, so I went a different direction with it, and I’ll post that project separately.
With this Jack O’ Lantern tutorial there’s a lot of separate cement mixing steps to this, but it goes quickly. I hope you enjoy it.
If you love making crafts with concrete and cement they you may be interested in my article where I experimented on all kinds of cement and concrete mixes. I tested them and give a comparison. I also tested sanding and sealing effects. That article is here- Cement & Concrete Crafts Tests.
Another really informative one is the Concrete Pigment Tests. this one I tested some different types of pigments and how much would be needed. I also talk about different mediums for coloring concrete after it's cured.
- Plastic pumpkin
- Cement-All, Rapid Set
- Latex/nitrile gloves- lots of them
- Disposable mixing bowl
- Disposable measuring cup
- Wide mouth cup or bowl to fit pumpkin top
- Battery operated outdoor candlelight
- *Heat gun- if you have one, otherwise use the heat tool listed next (Updated 10-13-19)
- Heat tool with razor blade head fitting
- Plastic bag
- Scissors
- Permanent marker
- Hot glue Glue gun
- Paper towels
- Construction adhesive
- Vegetable oil spray
Step 1: Remove the Jack O’Lantern’s Handle
First, remove the plastic handle from the pumpkin, just give it a tug.
Next, mark out the hole for the light on the bottom of the pumpkin by tracing around it with the marker.
Step 2: Create a Hole in the Top:
Cut a hole in the top to fit the candle. Start by making the cut just outside the line to allow the candle to fit easily. Using the heat tool, carve outside the line using a little pressure and a bit of a sawing motion. Please be careful and cut away from your body and your fingers! Once you have the hole cut, carefully punch it out through the bottom.
Make sure the candle light fits.
Step 3: Cut Out the Rest of the Pumpkin Parts:
Do the same for the eyes, nose and mouth of the pumpkin. Go slowly here so you don’t tear through the parts that need to stay intact. The plastic in the face is thinner and will cut easily.
Step 4: Fill in the Handle Holes:
Use the hot glue gun to fill in the side holes where the handle was. Just put a small dab on both holes.
Next, cut a piece of the plastic bag in a circle. Make it about 2” bigger than the top hole. Spray it generously with vegetable oil spray so it doesn’t stick to the plastic when you de-mould.
You are going to glue it around the hole, allowing it to be a little oversized so when you pour in the cement it will puff out a little to round out the head. This doesn’t have to be perfect, you will be refining this later.
With a paper towel, wipe off some of the oil around the edges of the bag where you will be gluing it. With the glue gun, place the hot glue about ¼” from the edge and start to attach the cut bag to it. Keep going until it is glued all the way around.
You may want to do a second run of glue to be sure it won’t leak. Then trim off any excess plastic, if there is any.
Step 5: Make Your Cement Mixture:
Mix up the cement. You will want it fairly runny, like a milkshake (not a thick one).For this project, I intentionally didn’t mix the cement mixture well because I didn’t want the pumpkin to have a smooth appearance, the way I do when I make planters since I wanted the pumpkin to be creepy looking.
Next add the cement to the disposable bowl, then add water and mix, continue doing this per scoop of cement. I used about 4 not-full scoops of cement for the mix.
Step 6: Pour the Cement Mixture:
Turn the pumpkin upside down so the plastic is downward. Pour in the mix and keep turning the pumpkin to coat it inside. Move quickly as this will start to cure fast. In some spots the cement won’t want to stick, so just use your hands to scoop some onto those spots and to even it out inside.
Let the cement fill and puff out the plastic bag. If you miss some parts of the pumpkin, it’s okay this will be refined in the next step.
Let the pumpkin rest on the wide mouth container with the bag inside to let it cure properly. Using paper towels, wipe off any cement that has dripped over the edges of the openings. This will make it much easier to de-mould (I made the mistake of not doing this as you can see in the photos). Let it cure for an hour.
Step 7: Reinforce the Mould:
You want the pumpkin to be fully coated and the area around the face to be thick so it doesn’t break when de-moulding. So mix up a thinner batch of cement, smoothly this time and pour into the pumpkin and roll around. You may need to use your gloved hands to hand apply the cement to coat the areas around the face. Let it cure.
Step 8: Demould the Cement From the Jack O’Lantern:
***UPDATE*** Since I originally posted this tutorial, I have discovered the magic of a heat gun. If you have a heat gun, I recommend trying that first. It will be a little easier than the heat tool.
Put the blade under the plastic skin and pull upward and slice sideways, continue to cut across the pumpkin. Keep pulling up with the blade so you don’t scratch the cement. You may need to repeat this near the face as well.
Once you get it opened far enough, you should be able to easily pull the plastic away like you are peeling an orange.
Step 9: Create the Base for the Stalk:
Now, mix up a little bit of cement into a thin slurry and coat the top of the pumpkin where the stalk will go. Just pour it on top so it fills in and rounds off.After a few minutes, take a toothpick and duplicate the lines from the pumpkin so that they look like they continue into the top. Let it cure.
Step 10: Create the Actual Stalk:
Now mix up a little bit of cement into a thin slurry and coat the top of the pumpkin where the stalk will go. Just pour it on top so it fills in and rounds off. After a few minutes, take a toothpick and duplicate the lines from the pumpkin so that they look like they continue into the top. Let it cure.
Once the top of the head has hardened, take the remaining part of the plastic bag and cut a rectangular piece and spray it with the vegetable oil spray. Mix up some more cement, this time thicker, let it cure about 5 minutes so it is more mouldable. Plop it onto the bag and wrap it.
Twist the bag slightly and pull to make the pumpkin stem. Fold the bag over to hold the cement in on the bottom and tie a knot in the top.
Step 11: Adhere the Stalk to the Cement Jack O’Lantern
Once the stem has cured, glue it with construction adhesive. It should fit the pumpkin head nicely and hold easily while the glue cures. After 24 hours, it will be permanently adhered.
Step 12: Turn on the Light!
Add the three AAA batteries to the candle light, turn it on and insert it into the pumpkin. I love the way this turned out! What do you think?
