Introduction: DIY Oil Lamp - Easy, Customizable Smell
In this instructable, you will learn how to make an oil lamp!
This is part of the Instructable Oil Contest.
Step 1: Step 1: Materials
For this Oil Lamp you will need:
- An empty water bottle
- A knife or piercing object of some sort
- Cotton Rope or Wick
- Olive Oil
- Mason Jar
Optional Materials Are:
- Lemon
- Rosemary
- Tyme
- Water
- Food Coloring
Step 2: Step 2: Piercing the Water Bottle Cap
Take the cap of the water bottle and put a hole through it using the knife (or similar object).
Make the hole only big enough that you need to slightly force the wax or cotton string through.
Step 3: Step 3: Put the Wick or Cotton Through
Put the cotton string or wax through the hole you made in the bottle cap, in such a way that the top of the bottle cap is facing away from the end of the cotton string or wick. The cotton string or wick should create a water tight seal in the bottle cap.
Step 4: Step 4: Cut the Wick or String
Cut the end of the cotton string or wick long enough that when you place it in your jar the bottle cap is about 3/5th the way up the jar. The seal in the bottle cap should still be air tight.
Step 5: Step 5: Filling the Jar
Fill the mason with oil 3/5th full. This oil will get absorbed by the wick or cotton string, making it burn easier and brighter.
Step 6: Optional Step: Lemon Scent
If you want to, you can put a slice of lemon in the bottom of the mason jar. This will give your oil lamp a citrus smell when it burns.
Step 7: Optional Step: Adding Spices
If you want, you can add some spices to the jar. This will add some scent to the jar and will make the oil lamp look better. I recommend you add 1 of these 3 spices:
- Thyme
- Rosemary
- Lavender
Don't add more than 1 because the smell with be very mixed when you burn the candle, causing an almost unpleasant aroma.
Step 8: Optional Step: Adding Colored Water
If you want, you can add colored water to the mason jar. Color the water by using generic food dye. The water will sink to the bottom of the jar, allowing the candle to still burn but also giving a cool layered effect.
Step 9: Optional Step: Adding Colored Water
This is the result of the colored water being added to the oil lamp.
Step 10: Option Step: Adding Colored Water
This is just a cooler photo of the oil and water being mixed.
Step 11: Step 11: Adding Everything Together
Add in the optional steps if you want, and place the candle wick / cotton string on top of the oil lightly, so that no oil gets into the bottle cap.
Step 12: Finished
Congrats! You're now finished making your oil lamp!
Please vote for this in the Oil Instructible Contest! Thanks!
Step 13: Dedications
This is dedicated to 2 people:
Mr. Mathew, for being an awesome teacher and inspiring me to make this.
My Dad, for inspiring me to be an engineer and creator.
Thank you for helping me in my journey.
Oil Contest
3 Discussions
Question 2 years ago on Step 13
I was just wondering...the plastic bottle cap-does it get hot enough to melt? If it burns down to halfway in the jar or a quarter way...I haven’t seen one built like this and am very inspired! Thank you for sharing! I was also wondering if other oils would be acceptable, like almond oil or coconut oil (liquid form)?
Answer 2 years ago
Thats a good question.. Might want to try a beer cap or something...
2 years ago
Great first Instructable. You should enter this into the Oil contest that is currently running.
