Introduction: DIY Polymer Clay Necklace
Hi! My name is Lindsay, I blog over at Southern Lovely.
Have you seen some of the adorable rose necklace & earrings out there?? I have purchased a few of them here & there, but have always wanted to make my own. When my cute blog friend, Lindsay , shared a tutorial for making them, I knew I had to give it a try!
So here it goes-
Step 1:
Gather materials
-polymer clay (I purchased mine at Michaels)
-necklace chain (from Michaels)
-pendent clasp (from Michaels)
-razor blade or box cutter
-hot glue gun (or Krazy glue)
Step 2:
Roll 6 small balls of clay, then flatten them with your fingers.
Step 3:
Fold one ball in half, I ended up rolling it to make it tighter for the center piece.
Step 4:
Then wrap each flattened piece around the center part that you just rolled up, creating the petals.
Step 5:
Cut the end of your flower off, depending how big you want your rose.
Step 6:
Bake at 275 degrees for 15 minutes
Step 7:
Attach your freshly baked rose to the pendent of your necklace with hot glue (or Krazy glue)
Step 8:
Of course I had to buy several colors, because that's how I like to do these around here. :) Can't wait to make more!
Play with Clay Challenge
8 Discussions
8 years ago on Step 7
How do you attach the pendant to thenecklace? Do you make a loop hole?
You can make a loop hole with plyers on some thin wire. Or you could go to your local craft store and they should have something called eyepins or headpins.
9 years ago on Introduction
I don't have that colored clay, so can I just knead in some food coloring?
Yes, that may work, or paint, or maybe embossing powders, or use a different color. Even white would be pretty! Mix colors of the clay together, do whatever. Remember, if everyone has exactly the same things as everyone else, we all stop being unique.
Lovely!
Thank you!
Excellent pictures. A wonderful addition to the Play with Clay Challenge! Good luck.
Thank you! I appreciate your kind words!
