Introduction: DIY Synthetic Dreads: Sealing Method 1
This tutorial follows my first one, DIY Synthetic Dreads: How to Make Solid SE Dreads...
In this instructable, I will teach you one method of how to seal and finish off those lovely dreadies in order to get them ready to wear.
(This will teach you how to seal dreads using the straightener method)
Step 1: Materials
This step of dread making is fairly simple and you don't need that much. Just stuff you can typically find around your house.
You will need a few different things for this process:
-A good straightener (one of the older low heated ones work best...NOT the ones that go up into the 100's)
-A bowl of water
-A lightweight wash cloth
-A pair of scissors
Step 2: Twisting
After you have your dread hooked up, backcombed and ready to go, we can begin twisting.
Twisting is another important part for the end result. Be sure when you twist the dread you twist it consistently and in the same direction all the way through (obviously.) Twist from top to bottom all the way down to the tail end, but if it's easier while you work, you can twist in stages to keep it tighter. (Like in the picture, I twist that far and hold it while I seal that part and then move down more.)
Step 3: Set Up
This step is as easy as could be. Simply take your wet wash cloth and lay it flat over the twisted dread.
Make sure that cloth is squeezed out but not too dry. You need it to be wet enough so that when you run the straightener over it, it will cause it to steam (and therefore sealing the dread.)
Also, remember to keep the dread twisted as tight as possible.
Step 4: Sealing
Now it's time to seal those beautiful dreads.
With the wet cloth laying over the dread, keep it twisted tight and clamp the straightener lightly over the covered portion of the dread. This will cause it to steam and while you do this the dread will shrink! Don't worry, that's the point. As it shrinks, just twist it tighter.
As you move down the dread, lay it back and check your progress. The dread should look slightly smaller and much tighter. When you touch it, you should feel that it is nearly solid. Poofy parts can always be gone over again.
*When you do this be VERY careful with the steam, it is so so so easy to burn yourself*
Step 5: Sealing the Tail
When you get down to the very bottom of the dread, you can set the wash cloth aside. Take your straightener (on low heat, around 30 works,) and clamp it quickly on the smaller part. If you leave it there for too long, you can burn straight through the hair and it will just fall off.
So carefully clamp the straightener a few times until you feel that the end has been sealed tightly and solid.
When you finish the tail, there will be a little fluff of hair off the end of the dread (picture 2). Just cut that part off up to where you sealed the tip and throw it away.
Keep in mind the more sealed the tip is, the better.
*Watch your fingers*
Step 6: Done!
Your dread is now officially done and ready to wear!
There should be a single loop at the top and it should get progressively smaller from top to bottom.
Look out for my next tutorial on installing single ended dreads!
Thanks and hope it helped :)
***I ALSO SELL THESE DREADS AND ALL OTHER DREADS FEATURED ON MY INSTRUCTABLES. IF YOU WANT TO PURCHASE THEM, MESSAGE ME! I'M ALWAYS AVAILABLE FOR ORDERS, AND I KEEP MY PRICES VERY MANAGEABLE! IF YOU WOULD RATHER NOT MAKE THEM YOURSELF I WILL GLADLY MAKE THEM FOR YOU.***
20 Comments
Question 2 years ago on Step 3
What do you suggest to hold/clamp the ends while laying the damp towel on it if you’re doing this by yourself, please?
7 years ago
how do you apply the dreads to your hair?
Reply 6 years ago
I think you need to clip them with a hair pin in the roots of your hair. I just removed my real dreads cause my scalp reacted really bad when I braided them. I'm looking for alternatives that are removable.
Reply 5 years ago
They're braided into the hair, not clipped in. :) You use your natural hair as two strains of the braid and the dread as the third strand and braid, if you're using DE dreads, for SE dreads, it's the same, except you're going to pull your natural hair through the loop at the top of the dread, separate your natural hair into two strands, using the dread as the third and braid. If you have longer hair, you can "blanket stitch" braid your hair around the dread so your hair doesn't go so far down the dread as it would with normal braiding technique. However you decide to braid, you close the braid off with a rubber band, perferably one that matches the dread, but you can be fun and use colourful bands as part of your overall dread look. :)
10 years ago on Introduction
great tutorial and thank you for sharing! ^_^
I'd like to ask what about if you want thicker dreads and with multiple colors but not completely candy cane more organic in its color blend
also applying beads?
and curling their ends?
Reply 5 years ago
To do a multiple colored one to make it look real just add the needed amount of hair and start to seperat them and place one on top of the other and continue to do that until its all blended. If that makes sense. And they sell beads where you squeeze them together once there on made just for dreads.
6 years ago
I am interested in buying. Please contact me at phil11d3@hotmail.com
6 years ago
How much wool in gram do you usually buy to make 60 (a full head dreads)?
8 years ago on Step 6
Are you located in the Greater Boston area?
11 years ago on Introduction
Where do you buy your synthetic hair from?
Reply 11 years ago on Introduction
www.ikickshins.net is good. They have a lot of colors, and it's cheap.
11 years ago on Step 6
Can you use yaky hair to do dreads?
Reply 11 years ago on Step 6
i've never done it. Since kanekalon is designed to have the fibers meld together, its pretty much the best you can possibly do with synthetic dreads. To be honest, I don't know if yaky would work, but I wouldn't risk it. Also kaneokalon is muchhh cheaper.
11 years ago on Step 4
i have a question. i have a hair straightener but it doesn't have a knob. it have buttons to turn up the heat. which degree do i put on my hair straightener to seal the dreads and the tip of the dreads?
Reply 11 years ago on Step 4
Even if it doesn't have a knob, what are the temps it runs on? On the straightener I have that has buttons, I put it at about 160 or so, just watch out for major steam then.
this is really helpful! :)
btw what kind of strightener did you use?
thank you the method i found and used didnt work as well. My dreads ended up but being puffy dreads after a wear or two
Yeah, that is a major pain. And no problem :] The nice thing about this method, is you do the exact same thing to reseal them even if they do get puffy.
12 years ago on Introduction
haha this is the way i figured out on my own.. like exactly.. except the sealing the ends i was afraid to do that but.. i think seeing that its done alot i wont be soo afraid to do so.. :) thnx much for posting this!~
Reply 12 years ago on Introduction
haha same here and don't be afraid! I'm glad this helped you out :]
