Introduction: DIY Xena Warrior Princess Costume
Aiyiyiyiyi!
Strength. Intelligence. Ululations. What’s not to admire? If you’ve ever wanted to be like Xena, here’s the easiest part of the process: the outfit.
Learn to fashion your own chakram, the skirt, the boots, and the armor. You’ll be dressed to impress, lay waste to a costume party, or spurn the advances of Ares.
Required skills for this build:
sewing
leatherwork
clay molding
Step 1: Chakram
- Cardboard
- Silver and Gold Spray Paint
- Scissors
Step 2: Corset
Since I am not a master seamstress I decided to buy a corset instead of making one. However, if you are up for the challenge, there are some fantastic corset making tutorials on Instructables. Use these resources to make the top half of your costume.
Make your own Corset: https://www.instructables.com/id/Make-a-Corset/
Buy a Corset: I bought this corset
Step 3: Sewing the Skirt
This was one of my favorite parts of the costume to make and it was surprisingly easy!
Materials:
2 yards of brown pleather (match the color of the corset)
100 studs (mine were silver)
scissors
sewing machine
Large Flaps
Cut out about 16 flaps that are 3" wide and 20" long. The bottoms of the flaps should be curved.
Small Flaps
Make 9 small flaps. Each flap will have 9 panels on it. Cut out the panels as I did below. Attach them with a stud. I didn't sew these panels together I just used the stud and they stayed together fine!
Put it all together
Cut out a long skinny piece of pleather the size of our waist +5". Sew the small flaps to the pleather spacing them 2-3 inches apart.
Sew a round of large flaps behind the small flaps. Make sure the flaps are touching each other. Sew a second round of large flaps where the first round of large flaps meet so all the gaps are filled in so when you wear the skirt your skin doesn't show.
Attach to Skirt
Sew the belted flaps on the inside of the skirt. I also added some grommets for decorative detail.
Step 4: Cast Breast Plate Armor
I wanted to have real looking armor w/o being weighed down by metal. So I created armor out of latex. Its actually a really simple process:
Materials: you can find all of these materials at Douglas and Sturgess
Modeling Clay
Plaster
Liquid Latex
Design Armor by draw out on paper/cardboard how you want the breast plate to look. This will just be the 2D design.
Mold Clay into the 3D design of the breast plate. Spray the clay mold with a parting agent. This will let the clay separate from the plaster.
Pour the plaster over the clay model. Follow instructions for mixing the plaster. Make sure to build a wall around our mold before you pour so the plaster doesn't run everywhere. Once the plaster dries remove the clay from the plaster. I had to use a toothbrush to get some of the clay out.
Fill the negative plaster mold with liquid latex. I painted it in with a paint brush.
Once the latex is dry, paint the breast plate with a latex paint. I added hammer in snaps to the breast plate and the corset so it was removable like the real Xena outfit.
Step 5: Arm Bands
The accessories like the arm bands and the shoulder pads really made the costume come together.
Brown pleather fabric (same as you use for skirt)
You will need to cut two arm bands for each arm: the upper arm band (UAB) and the lower arm band (LAB).
UAB: cut a rectangle 4" wide and 1"-2" longer than the circumference of your arm.
LAB: spans from your wrist to just before your elbow. It goes straight around your arm, but make it a bit shorter than the circumference of your arm because you are going to lace this arm band up. The end near your elbow comes to a point, while the end near your wrist goes straight around.
Hammer in Snaps (or velcro)
This is to keep the UAB together. I found the snaps were much more robust. Follow instructions for on package to add them to UAB
Grommetsand Thin Brown Cord
Add grommets along the long sides of the LAB. Lace up the LABs by threading the cord through the grommets like you're tying shoe laces.
Gold studs:
Line the edges of the UAB with gold studs like these.
Add Detail: Cast armor or Paint Armor
I went an extra step on these arm bands and casted the detail in latex. For details on how to do this see Step 4: Cast Breast Plate Armor. If you want the same detail i suggest painting the pleather with gold metalic paint (I think this is the best way to go)
Step 6: Boots
The other element that I didn't make from scratch was the boots - for obvious reasons. I bought a pair of inexpensive tall brown boots from here.
I added painted and latex detail. Instead of casting the shapes I dried 1/4" thick sheets of latex and cut out the shapes from that. I glued the latex detail on with epoxy.
For extra detail, I added grommets to the top of the boots.
Step 7: Shoulder Pads
Materials:
Armature Wire (thick)
Armature Wire (thin)
Brown Pleather
Studs
Cut shoulder pads out of pleather. You can see the pattern I used in the pictures.
Sew a small sleeve in the middle of the shoulder pad to run a thin piece of armature wire through. This will allow you to shape the shoulder pads.
Run the large armature wire through a longer sleeve at the edge of the shoulder pad. You will attach the shoulder pads to the costume using this armature wire. I bent the armature wire for decorative detail.
Add latex detail and studs.
Step 8: Sword and Sheath
Make a simple sheath for your sword. I attached it to my costume with snaps. It was really easy to access. I also sewed a pocket in the sheath that I put my money/phone/credit cards in so I didn't need to bring a purse with me.
Buy Sword Here
Step 9: Xena Fights a Space Viking.....Who Do You Think Won?
Finalist in the
Autodesk Employee Halloween Contest
Halloween Epic Costumes Contest
19 Comments
2 years ago
Xena won the battle of course!
4 years ago
My 9 year old wants to be Xena for halloween. What exactly did you use for plaster, clay, and parting agents? Thanks. I've never molded before and don't know the technical names for the products.
Reply 4 years ago
My 6 year old, too.
5 years ago
Woo...look good design.
Remember this movie, BTW.
5 years ago on Introduction
I'm making this for Halloween! Thank you for sharing!
How big should each of the small flaps be for the skirt?
6 years ago on Introduction
Very nice! Thanks for the tutorial!
8 years ago on Introduction
Congrats, Carleyy! Love this outfit! ;-)
Beautiful costume!! An awesome job! :-)
This is intense!! Very well done!! Hummm as for who one the fight, that is hard to say, I could see where a Space Viking might get an upper hand, but let's face it girls rule, so Xena takes it in for the win!
Wow this really turned out great! I'll show it to my co worker as I've been telling her for years she would make a great Xena.
8 years ago on Step 9
Everything looks great, except for that carcboard thing. You should have made it out of the same stuff as the armor.
very nice, im sure Xena showed more leg than that!. i like Gabryelle better. even gavbe my daughter that name
Nice work!
Someone should do a Tron Version of the Xena Costume.
A good sharp utility knife will give cleaner edges when cutting the cardboard. I just had to cut out some weapons of the Xena Era last night and a razor sharp blade gave good clean crisp edges. Other than that it's a great job as is!
You certainly whooped that space viking, Great 'ible, love the costume.
This gal looks truly fearsome. Wouldn't want to be her enemy!
This is amazing! Great job, & thanks for posting the tutorial!
Mind you don't fall down those stairs Carley! Pesky vikings.
That's no way to treat a space viking!
(And where's the ible for the EL sword?)
