Deseed Pomegranates in Seconds
101,024
36
18
Introduction: Deseed Pomegranates in Seconds
How to deseed a pomegranate quickly without staining your fingers or making a big mess.
Step 1:
Grab the most luscious looking ruby colored pomegranate at your local grocery store.
Step 2:
Take any sharp kitchen knife and slice through the fruit  vertically.
Step 3:
Next get some sort of mixing bowl you have in your kitchen and fill it about half way with water. The bowl should be big enough for you to fit both of your hands in so don't go off and grab a cereal bowl, unless you eat cereal out of big mixing bowls.
Step 4:
Okay now take half of your sliced pomegranate and place it in the water filled bowl. Stick your hands in there and start peeling away the rind and separating the seeds from the white, fleshy part inside called albedo. The seeds will sink to the bottom of the bowl and the albedo and rind will float to the top.
Step 5:
Pick out the rind and white albedo that has floated to the top so that you are left with a water and seed filled bowl.
Step 6:
Drain the water and put your seeds in some short of dish, or smaller bowl, or whatever you want depending on what you want to do with them now. Congrats! You can now seed a pomegranate in seconds without staining your hands!
Be the First to Share
    • Anything Goes Contest
    18 Comments
    Varahi
    Varahi
    5 years ago
    short and sweet way
    SophiesFoodieFiles
    SophiesFoodieFiles
    5 years ago
    This is the most efficient way to do that! waw! I needed this method before!! Amazing! From now on, I will use this easy simple method! thanks!
    sabu.dawdy
    sabu.dawdy
    7 years ago
    I will try this up for sure
    ccarpio2
    ccarpio2
    8 years ago on Introduction
    U could boiled the water with pomegranate to make some juice :P
    Phoenix Flare
    Phoenix Flare
    8 years ago
    Do you eat the seeds or the white stuff or the rind??
    Kabuto
    Kabuto
    You eat the seeds usually. They have a very nice flavor.
    Great job! And I'm with jessyratfink, Nigella's way is a fast MESS leaving more juice splattered then collected. Much better way here
    BubbleandSweet
    Nice - my kids eat them all the time and are forever making a mess through the house with their sticky hands. We might try this. Thanks for sharing.
    Draxis
    Draxis
    10 years ago on Introduction
    Awesome job! I've been using this trick for years now and I must admit that I'm a little jealous that I didn't think of posting it myself! If I may just make a suggestion, instead of cutting it straight in half, try scoring the outside of the pomegranate (avoid going too far into the pith if you can), dividing it into fourths. Then, gently pull it apart along the cuts into halves, then quarters. By cutting only the outside skin of the pomegranate you keep most of the juice that you would have otherwise lost by cutting through the seeds. Other than that, great ible, keep up the good work!
    raviolikid
    raviolikid
    They are so beautiful! But, I don't know what to do with them...
    BobCat
    BobCat
    Don't cut all the way through, just cut the skin and rip it open underwater.
    Then take the jewels and put them in a ziploc bag, pound on it with your fist, open one end and pour out the juice.
    rimar2000
    rimar2000
    Thanks for sharing, I hate to peel pomegranates because I did not know this method.
    jessyratfink
    jessyratfink
    Very smart! I do love pomegranates, but they are awful about staining your hands, and Nigella Lawson's "cut it in half and whack it with a spoon" is so messy. I will have to try this. :D
