Introduction: Duct Tape Belt
Duct Tape Belt
Step 1: Duct Tape Belt (Easy)
What you need for this project:
~Duct tape
~Belt Buckle
~Ruler
Step 2: Measure & Tape
First off, measure your waist. You want to make the belt as accurate as possible so you don't have too much extra. Also, measure your belt loops to see how wide to make the belt.
Get your duct tape and draw out a long piece. Lightly grasp close to the middle of the piece and fold one half on top of the other. It takes practice to get good at this, so you might have trouble the first few tries. See the picture below for a visual. Squeeze out all of the bubbles in the tape and continue on until you have enough to fit around your waist.
Step 3: Cut & Connect
Mark the width of the belt loops on the strips of duct tape made in step 1. Using a ruler, make a line by extending the mark. Cut along the mark, and repeat for each piece. You can also just tear the duct tape from the first mark, which is easier.
After this, you want to join the separate strips into one with small strips of duct tape.
Step 4: Add the Buckle
Finally, you have a choice of buckles for the belt. You can harvest a regular one or use anything else that works for you.
