Duct Tape and Storage Bag Binder Pencil Pocket
12,298
80
8
Introduction: Duct Tape and Storage Bag Binder Pencil Pocket
You will need:
One gallon sized slider style storage bag
Duct tape in desired print or color
Plastic cutting mat optional (helps to cut the duct tape)
Ruler, marker, scissors
Three-hole punch or regular hole punch
1. Measure and cut 3 inches off the bottom edge of the storage bag.  Discard the cut off piece.
2. Measure and cut 5 pieces of duct tape to 10 ½” each.
3. Starting at the upper edge attach a 10 ½” piece of duct tape over the plastic of the bag and across. Press to adhere.  Repeat with three more pieces of duct tape overlapping just a bit where the edges meet to cover the bag. Overlap the bottom edge of the final piece and press to the opposite side.
4. Turn over to cover the other side.  Cut 4 pieces of duct tape to 12” each.  Start as you did on the first side except fold the extra length on each side (about ½” on each side) to the back. (Already covered side)
5. When you have completely covered the bag, you will need to reinforce the sides and bottom edge.  To do this cut 2 pieces of duct tape 7 ¾” each.  Press half the tape on one side covering any uneven edges and turn the excess to the opposite side.  Repeat on the other end.  For the bottom, cut another piece of duct tape 10 ½” and attach part to one side and fold the rest to the other side. (Bottom reinforced)
6. Use a three-hole punch to make holes for the loose-leaf binder along the bottom edge.  If you do not have a three-hole punch, use a piece of loose-leaf paper to trace where the holes should be and punch with a regular hole punch.
Maker Moms Contest
Maker Moms Contest
Office Supplies Contest
Be the First to Share
    • CNC and 3D Printing Contest
    • Halloween Contest
      Halloween Contest
    • Back to School: Student Design Challenge
    8 Comments
    DANCE2ME
    DANCE2ME
    10 years ago on Introduction
    Im sure it would be just as easy to cover the ziploc bag in duck tape then three hole punch it but great instructable!
    __________________________ Lyssa Luvs y0u
    rrkrose
    rrkrose
    This is a great idea! I would have never thought to do this with a ziploc bag.
