Introduction: Etched Glass Snow Globe
Recommended for ages 18 and up. In this set of instructions you will be using a sharp razor, hot glue, and a chemical etching cream.
Snow globes are a signature décor item during the winter holiday season. We see them on television, in our homes, and in every store. However, snow globes are getting fancier and therefore more expensive. Our solution to this problem is to learn how to make your own. A homemade snow globe not only is a way to customize how you express your love for the holidays, but it also adds a charm that you just cannot buy.
Step 1: Gather Your Things (Materials)
Etching Materials:
Armour Etch (can be found at a craft store such as Michael’s and Hobby Lobby)
Latex gloves (If you are allergic to latex, any plastic gloves will work, but we used latex)
Painter’s tape
Popsicle sticks
Letter stickers of your choosing
Smooth glass jar with lid
Glass cleaner (Isopropyl rubbing alcohol is preferred over regular glass cleaner)
Paper Towels
Snow Globe Materials:
Glass etched Jar with sealable top
Water to go in the Jar
Soap
Expressions Glycerin 8 fl oz bottle
Glitter
Figurine
Utility knife
Hot Glue Gun
Hot Glue Sticks
Popsicle stick
Piece of paper
Step 2: Prepare and Clean the Jar
● Clean the glass jar thoroughly using a paper towel soaked with isopropyl alcohol (rubbing alcohol)
● Rub jar dry with a dry paper towel
Step 3: Stickers
● Turn the jar upside down (the opening of the jar facing the table top)
● Apply stickers to the jar, spelling out desired word or phrase
● Be sure that the stickers stick completely so the etching cream cannot get under it
Step 4: Prepare to Etch
● Create a box of tape around the letters to isolate the etching cream to the center of the box
● Whatever jar is left exposed in the center of the box will be what appears etched on finished product
● Be sure to leave enough space between the sides of letters for etching!
Step 5: Apply the Etching Cream
● Put gloves on
● Use the popsicle stick to apply a thin layer of Armour Etch to fill the inside of the box (created with tape) and over the sticker letters that are inside the tape box
● Carefully wipe any spilled Armour Etch with a paper towel and dispose into a garbage can
● Wait about 5 minutes (over 5 minutes will not damage the project)
● During this step, occasionally tap or swirl the etching cream again to ensure there are no air pockets under the cream
● Do this gently so as to not mess up the stickers or tape
● Rinse off with hot tap water in the sink, using gloved hands to wipe the cream away
● Be sure that this is a stainless steel sink (not a porcelain sink)
● Once etching cream is washed completely off, use the water to help peel off the stickers and tape
● All done!
Step 6: Preparing the Jar
● Separate the lid from the jar
● Fill the jar to the base of the mouth with water
● Measure out 2 cap fulls of glycerin and pour into the jar of water
● Plug hot glue gun into outlet with glue stick inserted
● Place sheet of paper under hot glue gun for excess glue drips
Step 7: Adding the Decorations
● Unscrew lid from the jar
● In the center of the inside-facing side of the lid, score the surface with the utility knife
● Brush off debris from scoring
● Hot glue base of figurine to the scored portion of the lid (see video for more help)
● Let glue set and dry for 7 minutes
Step 8: Glitter!
● Pour in glitter (as much as your heart desires without overflowing the jar)
● Stir the glitter with a popsicle stick
Step 9: And Put It All Together Now
● Take lid with the figurine and screw the lid back onto the jar
● Make sure the lid is secured tight so no water can seep out
Step 10: Shake, Shake, Shake
● Appreciate what you made!
First Time Author Contest
5 Discussions
4 years ago
neat work, well done.
5 years ago
very cool!
5 years ago
very pretty good job!!
5 years ago
If i do this, I'd spray (or otherwise) paint the lid with gold or silver or a color to blend with what's inside the snow globe.
I live in a nursing home these days, due to a devastating illness last year. (I'm hoping to get out soon!). This might be a simple project for some of the residents here that the Activities Group to assist with. Let the Activities Staff do the actual etching part!
5 years ago
Awesome first instructable! I love the look!
