Introduction: FaceMask COVID 19 Proof
You'l be needing elastic fabric bands and prewashed (90°C) Cotton
Step 1: Wash the Fabric
Wash your Fabric at 90°C or 194°F. Otherwise you won't be able to wash it after you've used the mask.
Step 2: Cut Out the Fabric
Print out this PDF on A4 paper, check if the scaling is correct using the 5cm bar.
Then cut out the fabric for your mask
Step 3: Stitch the Nose
Stitch the nose on 1 cm and thin out the arc till 0.5cm.
Step 4: Stitch the Seam
Stitch the seam flat to one side (1mm)
Lay the top fabric and the lining with the right sides on top of each other and and stitch the top and the bottom to each other.
Step 5: Ironing
Rotate the fabric.
Iron the seems flat and stitch off the sides on 1mm.
Step 6: Elastic Band
Cut out the elastic band on 70cm and stitch the ends to eachother. (make a circle)
Step 7: Attach the Elastic Band
Lay the elastic flat on the mask and stitch the hem on 1cm with the elastic band between it.
Don't stitch the elastic band so you can still move it.
