Fondant Holly Wreath
1,480
5
Introduction: Fondant Holly Wreath
About: My name is Niki, I am a mum of three amazing grown up kids as well as a Grandma. I am a keen hobbyist and a full time carer for someone with a disability. In my spare time I indulge in my eclectic crafting …
This little holly wreath can be used as a centre piece for your cake or as a cupcake topper.
Can be made with, or without, a forming cup and there are a mix of images from both methods here
Another of my Festive Fondant creations. Click the link to see my full blog Festive Fondant index
Step 1: You Will Need
  • Modelling fondant / paste in red and green or
  • Modelling fondant / paste in white if colouring your own
  • Colour pastes in red and green if colouring your own
  • A 75mm Forming cup - optional
  • Water / edible glue
  • Paintbrush
  • Small (optional), medium and large holly cutters
  • Rolling pin
  • Edible silver and / or gold spray glitter (optional)
Step 2: Roll Out and Cut Pieces
Roll out your fondant as thin as you can without it breaking, then:
  • Cut 7 Large holly leaves
  • Cut 7 Medium holly leaves
  • Cut 7 Small holly leaves (optional)
  • Roll about 6 small red balls for berries
Step 3: Layer #1
Lay seven holly leaves around in a circle and leave only a very small gap in the centre.
Because I want to show you that you don;t need the forming cups, this image shows the first layer without.
If using forming cups, you won't need the greaseproof paper, but I strongly advise that you use some if you don't have a forming cup
Step 4: Layer #2
Add some edible glue or water to each of the leaves, about 1/3 of the leaf and concentrate on the edges of the leaves more than the middle
Add the medium sized leaves, as close to the centre of your project as possible, so they cover the join of the leaves from layer one.
At this point, you can stop adding layers and skip the next layer if you only wish to have two layers (image left)
Step 5: Layer #3 (optional)
If you'd like just two layers, skip this step.
Add your third layer, again as close to the centre of your project as possible.
Using glue / water on the joins of the previous layer about 1/3 of the way up the medium leaf, place the smallest of your leaves on the joins of the medium leaves.
Step 6: Add Berries
Start with the centre, glue your first berry on.
Then, glue a further five on surrounding this first one.
Step 7: Add Some Festive Magic
Otherwise known as edible glitter, add some festive magic to your creations.
Allow to dry and harden before topping the centre of your Christmas cake or festive cupcakes
Be the First to Share
    • Microcontroller Contest
    • Eggs Challenge
      Eggs Challenge
    • Fandom Contest
      Fandom Contest
