Introduction: Giant Syringe for Halloween
Since I made a papier mache plague doctor mask for halloween, which should go well with a long dark coat and large hat, I realised that the final piece of the costume was a syringe which the shops don't seem to sell around here. WIthout it I'd be unable to make the kindly offer of a "free plague jab" to trick or treaters.
Step 1: Materials/Tools
I didn't take any photos of the first stage because I wasn't intending to make an instructable then, but it's fairly simple to do. You'll need:
An empty tube of caulk/filler/sealant, a long stick and a hacksaw. Chop off the end with the hole in it about one centimetre down (this will be the needle end of the syringe) and poke out the internal bung with the stick (this will be the blunt end).
A plastic bottle (I used a two litre lemonade) and some sharp scissors. Cut the top and bottom off the bottle and roll it to fit the ends of the capsule. Add a layer of sellotape to hold it, and glue one end in place.
A caulking gun (presumably you'll have one around, if not then they're a few pounds at a DIY store).
A clear plastic straw and a bolt (optional but I think it looks quite nice). Cut the end of the straw at a slight angle with the scissors and screw it into the bolt if youre using one.
Step 2: Constructing the Capsule
Glue one end of the rolled plastic into a capsule end, make sure the other fits fairly snugly.
You'll want one end to be removable to get the glow stick out later (unless you want to spend hours shaking it and hoping that it falls out, or you intend to gradually fill the capsule to the brim with old sticks).
Glue the bolt and straw to the needle end. The bolt makes it look more real to my eyes, and gives a larger surface for the glue to hold on.
Step 3: Final Assembly
As with the rest of this, the final step is easy. Place the capsule in the caulking gun and tighten the lever just enough to hold it in place. Since I had a black caulking gun, I decided to leave it unaltered which also reduced the chance of gumming the works up with paint.
Before I put a lit glowstick in the syringe (I've also lost my glowsticks, which is a bit inconvenient, so can't provide a lit picture atm), I've decided to line it with greaseproof paper to diffuse the light a little.
And that's all he wrote, hope it works well for anyone else using this instructable.
Halloween Props Contest
