Introduction: Halloween Light
This is a pretty lantern to make for halloween decor.
Step 1: Making the Base
You can use a wire clothes hanger or any other bendable metal to make the base.
Step 2:
Cut 6 inch and a half pieces
Step 3:
You will need this tool
Step 4:
measure the wire circumference to make sure the wirewill fit the jar
Step 5:
Use this tool to make sure it is a perfect circle.
Step 6:
Sauder the circle closed
Step 7:
sauder the inch and a half pieces to the circular piece
Step 8:
Make another circle slightly smaller
Step 9:
Sauder it to the other end of the stick things
Step 10:
Cut more sticks for more support
Step 11:
Bend them into an angle you like
Step 12:
I give up
Step 13:
sauder it so it makes this
Step 14:
more bending
Step 15:
This will be your bottom support
Step 16:
pain the jar however you like
Step 17:
Put a candle in it after it is dry
Step 18:
set car on stand. And you're done
