Introduction: World of Warcraft Hearthstone Plaque
Home is where the heart is but, in World of Warcraft, it’s also where the hearthstone is. Give your favorite player a place to truly call home with this hearthstone handmade by you. This plaster replica will hang flat against a wall or can be used as a unique office decoration.
Using modeling clay to create a single-use mold for both the roughly-hewn edges of the stone and the engraved rune will make each hearthstone unique. Because modeling clay is so flexible, there is no worry about undercuts in the unmolding process.
Step 1: Supplies
- Modeling clay (NOT Play-doh)* - white or grey are best; colored clays may transfer color to the plaster
- Plaster of Paris
- About 6" of copper wire**
- A piece of clear, smooth plastic - large zip top bag or plastic from a product package
- Paperboard scrap, lumber, cookie sheet or similar for a work surface - must be flat
- A variety of tools for shaping plaster: a craft knife and sandpaper; plastic or wooden clay tools if you have them
- Paper or plastic container for mixing plaster, at least 3-4 cups volume
- Popsicle stick or other implement for mixing plaster
- Water
- Hearthstone template - this is about 3½" X 4½" but I have also included the picture file so you can scale it up or down if needed. If scaling, please remember to scale the sizes and amounts of supplies accordingly.
- Acrylic craft paints, etc. for finishing - this part is up to you (see final step for ideas)
**I used copper because it won't rust. Aluminum will also work. Select wire that can hold the weight of the finished product which is a little less than a pound.
Step 2: Preparation
Lay your work surface on a table or counter. Put down your template and place your clear plastic over the top.
Step 3: The Hanger
- Shape a rectangle of modeling clay about 1.5" X 1" X 1/4" thick.
- Lay the center of the wire across the modeling clay, as shown. Fold the clay over, encapsulating the wire in the center.
- Curl the ends of the wire. The wire is not likely to slip out but this is a further measure that I like to take.
Step 4: The Rune
- Roll out a clay snake approximately 8” long and 1/4” diameter.
- Cut the ends as shown, with opposing angles.
- Lay the clay snake on the plastic over the template and gently flatten, pressing it into the plastic for a good seal.
Step 5: Finish the Mold
- Create a strip of modeling clay about 16" long, 1" wide, and 1'2" deep. Don't make it a perfect strip. You want a lot of variations in thickness.
- Lay this on its side all the way around the perimeter of the template, pressing down firmly to create a good seal against the plastic base.
- Create a rough bevel by angling the clay edge out slightly as you move up, away from the plastic
Step 6: Pouring the Plaster
- Pour approximately 3/4 cup COLD water into the mixing container.
- Add 1 ½ cups plaster to the container and mix thoroughly.
- Tap on the sides of the container or pick up the container and bang it on the counter lightly to release bubbles. You'll be tapping the mold as well but it's good to release bubbles in both steps.
- Pour the plaster into the mold you’ve prepared. Pour into the swirled section and allow to spread from there. Fill until nearly to the top. Tap the mold or the surface it's on to even out the top and release the bubbles. Tap vigorously until bubbles stop rising to the top. If your work surface is not flexible, you can also pick it up and carefully tap it directly onto the counter to release bubbles.
- Drop the hanger assembly into the plaster toward the top and centering. Press the wires extending out of the clay into the plaster. For good measure, tap again.
- Allow the entire thing to set about half an hour or so.
Step 7: Unmolding and Shaping
- Once the plaster has hardened to the point where it won't retain a dent when pressed, you can peel away the clay from the edges.
- Using a toothpick or plastic tools, pry the clay out from around the hanger to expose the wire.
- Turn it the piece over and pry the clay out of the engraving.
- Use your tools to smooth and shape the edges, including the edges around the engraving to give it a roughly chiseled look. You might want to shave some of the plaster away from some areas and sand it away from others.
- Once you are satisfied with the look, allow to cure for at least two days.
Step 8: Finishing
The process of finishing the stone is up to you. It can be painted with acrylic craft paints and sealed with craft paint in different finishes, according to your taste. I thought that the stone should be a matte greyish-white and the engraving should be a glossy jewel-tone blue. But this is my personal preference.
If you are going to hang this, it's good to seal the back with acrylic sealer or cover it with sticky-back felt because plain, dried plaster can leave chalky residue on a surface.
This is how I finished mine:
I thought the color of the texture of the plaster was perfect. The engraving was a different matter. I tried blue RTV silicone but what I had on hand, while the perfect shade of blue, was opaque, not translucent. In the end, I used a dimensional fabric paint, Tulip Gellies in Blue (there is no glitter in this and it gives a jewel-like appearance.) I am very pleased with the results. If that had not worked, I would have next tried a translucent blue faux stained glass paint to give a similar look.
6 Comments
7 years ago
I used homemade plaster...waiting for it to dry
8 years ago on Introduction
I Love Runes. My Mom is from Norway.
awesome
10 years ago on Introduction
Great idea, and easy to do! I can see this being placed in some clever areas around the house entrances lol
12 years ago on Introduction
Awesome.
